Old 12-23-2008, 05:21 PM   #1
jrwoodchuck's Avatar
Default 8t gears in a 8b?
I think I herd this someware, and is there an advantage? Or am I just smoking crack?
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 12-23-2008, 07:37 PM   #2
8&stuff's Avatar
Trader Rating: 55 (100%+)
they are the same.
Mark Buecker
8&stuff is offline   Reply With Quote
Old 12-23-2008, 07:44 PM   #3
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Originally Posted by 8&stuff View Post
they are the same.
well no they arent. The truggy gears are geared for the larger diameter tires. The truggy gears have a 43/10 ratio as the buggy gears have a 43/13 ratio. I have heard of people running truggy gears in buggy but I believe you have to use a smaller spur and or a bigger clutch bell to get the right gearing for a buggy. In theory this would reduce rotating weight(I think) and I believe I heard it makes the buggy snappier. I don't see the need for it as the losi is already one of the snappiest/quickest accellerating buggys out.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 12-23-2008, 08:01 PM   #4
Tiggertrucks's Avatar
Trader Rating: 51 (98%+)
i thought about using 8b gears in a 8t just to reduce the punch(i got a LOT of motor and i have a heavy trigger finger) but i never got around to doing it cause i sold the buggy
has anyone tried it?
TLR 22t 2.0
Tiggertrucks is offline   Reply With Quote
Old 12-23-2008, 08:07 PM   #5
8&stuff's Avatar
hmm..i knew or heard that but forgot..so is that the ring gear thats different 13&10?
Mark Buecker
Old 12-23-2008, 08:17 PM   #6
cornerspeed's Avatar
Pinions.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 12-23-2008, 08:53 PM   #7
Trader Rating: 14 (100%+)
the buggy runs a 43 tooth ring gear and a 13 tooth pinion gear with a 46 tooth spur and 13 tooth clutch bell. you can run the 10 thooth pinion in the buggy but you will have to run a 44 tooth spur with a 16 tooth clutch bell. or a 46t spur with a 14-16 tooth clutch bell this is all depending on the track you are running on. The benefits will be less rotating mass and better punch and a little smoother power transition. most of the new cars on the market run this gearing now. As for running the 13t pinion in the truggy you would have to run a 62t spur to get the gearing right. it wouldnt really help in any way. Hope this helps a little.
"Peasey"
Special thank to my sponsors.
Airtronics, Rc Country Hobbies, Rc Renew, Triton Engines, Lutz Rc
Josh Pease is offline   Reply With Quote
Old 12-23-2008, 10:13 PM   #8
Actually the buggy and truggy run a 48t spur. And don't be confused, if you want to run the 10t pinion you have to use the truggy specific ring gear. Why, you say. well because the 10t pinion has a smaller overall diameter the ring gear has been adapted to mesh with it correctly. If you tried to run a 10t pinion with buggy ring gears it would not lign up properly.
-Koby Kubrin-
Old 12-23-2008, 11:23 PM   #9
losi_racer's Avatar
Trader Rating: 25 (100%+)
a guy at my race track who is sponsored by losi has truggy gears in his losi 8ight 2.0. so it will work
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 12-24-2008, 07:00 AM   #10
In the Losi 8 setup thread a guy named Tex1 discuss the advantage to do this setup quite deeply, as some one said before in order to have that advantage you need to use a 16T bell, which at that time (before the 2.0) you were forced to use a Ofna one, which also meant to change your clutch.
If I remember correctly with the announcement of the 2.0 a Losi 16T bell came out with the right spur, and you could change the gears from the truggy to the buggy.
The reason to do the change resides in the fact that cars like RC8, 808 and others are coming out with that relationship. It allows the engine to keep rotating before applying the torque to the wheels, so when you come out of the corners for one thing your engine is rev ed up already so when you apply the throttle it will be smoother coming out.
That is what I understood fo that discussion at that time, but you must take into consideration that the 2.0 is a different car and the new smart diffs are coming out also.
cota348 is offline   Reply With Quote
Old 12-24-2008, 08:14 AM   #11
8&stuff's Avatar
Either way 2 or 1.0 sounds like it could be worth a try
Mark Buecker
Old 12-24-2008, 08:44 AM   #12
Integra's Avatar
X2.
Old 12-24-2008, 08:45 AM   #13
losi_racer's Avatar
once i see the driver who has the truggy gears in his 2.0 ill ask him what the advantages are and let u guys know
Old 12-24-2008, 08:48 AM   #14
CaseyP's Avatar
I have been running it lately and Like it. 45 16 with black and green at the pit and 47 16 with green gold on the smaller tracks. My clutches have been lasting forever. Thanks to Billy Fischer for the testing on this.
<>< The Truth Will Set You Free!
TLR / Team Orion / Spektrum / AKA / TEKIN / Horizon Hobby / upgrade rc / AVID / SCH / SPY / HAL'S HOBBY WAREHOUSE
CaseyP is offline   Reply With Quote
Old 12-24-2008, 09:59 AM   #15
MikeFriery's Avatar
Trader Rating: 19 (100%+)
The advantages are more bottom end on small technical tracks. At big open tracks, there isnt much advantage. The only reason we still run it at places like the Pit is so we dont have to change back and forth.
AKA / RedRock Hobbies / Shuurspeed
MikeFriery is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Kyosho ST-RR $430 shipped mbunker R/C Items: For Sale/Trade 11 05-05-2009 07:08 AM
Losi 8b and 8t gasman517 R/C Items: For Sale/Trade 14 11-30-2008 02:50 PM
Team Losi buggy and truggy, engines and more!!! SupermaxxRich R/C Items: For Sale/Trade 21 09-07-2008 07:46 PM
Jammin X1-X roller w/ spares wild gopher R/C Items: For Sale/Trade 10 08-06-2008 10:13 AM
