Old 12-24-2008, 10:37 AM   #16
cornerspeed's Avatar
I remember the post's from Tex1 about this. I think he was running a 18T clutch bell. I don't remember the spur. Losi has released a 17T and 18T clutch bell's. I know I am gonna try it soon. I have all the parts. Just waiting to get a second car to do it on.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 12-26-2008, 05:52 AM   #17
TonysScrews's Avatar
It's possible that TEx1 is running a brushless conversion. I have the MBX5T ring & pinion gears in my MBX5R buggy for this reason. I was running a very high KV motor and needed to gear my MBX5R down more. I was already using an 11T pinion and didn't want to go down to the 10T. I actually wasn't afan of the 11T either. With the truggy diffs I was able to go back up to a 14T pinion and smaller spur gear. The car ran much better.
As for doing this in a nitro car, the only two advantages I can see are:
1] you can run a smaller spur gear which is lighter. Less rotating mass = quicker acceleration. Plus the motor will likely move more towards the center line of the car even though you're going up on the clutch bell.
2] taller clutch bells (15T or taller) feel much smoother than the small clutch bells we're used too. The gear mesh just feels smoother.
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 12-26-2008, 08:00 AM   #18
tex1's Avatar
Send a message via Yahoo to tex1
Thumbs up 8B with truggy gears...
Actually the 10 tooth (Truggy gears) input to the diffs means the center diff spins at more RPM for a given wheel speed (you can only roll so fast in the corners) when in the corners. This means the motor does not have to work as hard comming out. This is what makes the car feel more punchy. If you carry any rolling speed at all in the corner the thing will feel like a rocket when you apply power on exit.
However, when you are at a dead stop the motor will not spin the tires loose because of the increased ratio.
Losi has since come out with new gears that make it possible to go to this setup using their stuff.
The Losi 45 spur combined to the 17T clutch bell should be killer. 11.38/1 is a solid ratio to start.
You do not need as much clutch either. I ran 3 carbons with green on 2 and gold on 1 & one longlife aluminum on 1 gold spring. This clutch lasted for ever.
I have setup several cars for people this way and they have all said it was way easier to drive. Around the corner with speed... roll the throttle a little and you hit the jump. Done deal. Better fuel milage to boot. You just don't need to be on the gas as much.
This is why alot of other manufacturers are going to these mid 11/1 ratios.
Beware - For you newer guys to this stuff. The car will be totally different! Rolling and punching the throttle will be ballistic. From a dead stop it will be more mellow.
Thanks for really looking into this Casey and Billy. I gave up on it when discussing it with Losi in 07'. Good to see some eyes open up.
TEX
tex1 is offline   Reply With Quote
Old 12-26-2008, 09:29 AM   #19
Integra's Avatar
Nicely said Mr Tex.
Old 12-27-2008, 08:57 AM   #20
My car is now set-up with the 8T gearing. Gonna try it out today for the first time. Looking forward to it. I made a little gearing chart, with the assistance from Tex1. The overall gearing is on the left with the highest to the lowest. This way I can look at this and determine what bell and spur to change for any given overall.
8T Gearing in 8B
11.22 ------------- 47/18 = 2.61
11.38 ------------- 45/17 = 2.64
11.46 ------------- 48/18 = 2.66
11.88 ------------- 47/17 = 2.76
12.09 ------------- 45/16 = 2.81
12.14 ------------- 48/17 = 2.82
12.63 ------------- 47/16 = 2.93
12.90 ------------- 48/17 = 2.82
Stock Gearing 13/43 13/48
3.30 3.69 = 12.18
Donny Vinkemulder
TLR Driver
Old 12-27-2008, 11:33 AM   #21
jrwoodchuck's Avatar
well moot point now, i just bought an 808. it allready has the different gear ratio. thanks for the input and sorry to waste anybodys time.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 12-27-2008, 10:02 PM   #22
MikeFriery's Avatar
Trader Rating: 19 (100%+)
One thing to remember :
48 / 17 and 16/ 45 are almost the same gear ratio.. but 17/48 moves your motor WAY out from center
AKA / RedRock Hobbies / Shuurspeed
MikeFriery is offline   Reply With Quote
Old 12-29-2008, 04:29 AM   #23
The LOSA3552 is the 45T spur for the 8, but Horizon shows that it is for the 8E, does any know if it would work in the nitro 8?
cota348 is offline   Reply With Quote
Old 12-29-2008, 06:26 AM   #24
tdeal823's Avatar
Trader Rating: 30 (100%+)
yes you can run the "E" spur.
the kyosho spurs fit also
tdeal823 is offline   Reply With Quote
Old 12-29-2008, 06:55 PM   #25
Where do we find the 17T bell for the Losi?
Whosold is offline   Reply With Quote
Old 12-29-2008, 07:00 PM   #26
http://www.horizonhobby.com/Products...rodID=LOSA9121
Doug
TLR 22/M-11
Old 12-29-2008, 07:07 PM   #27
Thank You.
Old 06-03-2009, 12:32 AM   #28
Trader Rating: 27 (100%+)
Hey fellas, kind of bringing this one back. I picked up an 8b which has the spur fairly worn so I will be picking a new one. Is 16/45 a good setup to run on the buggy?
This is what I gather from the thread, but just confirming. Thanks
edit: or even numerically smaller? 15/43 or something? to keep engine closer to center-line
spawn_x is offline   Reply With Quote
Old 06-03-2009, 01:46 AM   #29
losi_racer's Avatar
Trader Rating: 25 (100%+)
the stock gearing is 48/13, its a good combo and keeps the engine center
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 06-05-2009, 10:25 PM   #30
Sorry confused a bit, you are suggesting I use 48/13 or comparing it to 48/13? you are right I do have a 48/13 on the buggy now. Thanks my friend
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Kyosho ST-RR $430 shipped mbunker R/C Items: For Sale/Trade 11 05-05-2009 07:08 AM
Losi 8b and 8t gasman517 R/C Items: For Sale/Trade 14 11-30-2008 02:50 PM
Team Losi buggy and truggy, engines and more!!! SupermaxxRich R/C Items: For Sale/Trade 21 09-07-2008 07:46 PM
Jammin X1-X roller w/ spares wild gopher R/C Items: For Sale/Trade 10 08-06-2008 10:13 AM
