Old 12-23-2008, 01:56 PM   #1
drs92's Avatar
Trader Rating: 36 (100%+)
Send a message via AIM to drs92
Questions?? Go .21 5 port or Go .25 6 port
Just like the title says which should i get for a kyosho st-rr? I can get the 5 port for 190 shipped or .25 for 195 shipped! Does the turbo plug have an advantage or standard? Im buying in like 3 days so all the help i could get will be great!!!!!
drs92 is offline   Reply With Quote
Old 12-23-2008, 02:20 PM   #2
22Racer's Avatar
Trader Rating: 67 (100%+)
To make a good suggestion we should know:
Track style- big, small, tacky, dry?
driver level- newbie, inter, expert
What motor did you run before and what were you lacking?
Both motors tune easy and break in about the same so there is no difference that way.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 12-23-2008, 02:28 PM   #3
bluer322's Avatar
I ran the 5 port very good motor. The turbo plug helps get better fuel millage. It depends on the track, the 5 port has plenty of bodom,I don't know about the 25 might be to much, let someone who ran it tell u that. If you got the 25 i guess you could tame down the bottom by clutch set up and a mild trigger finger. The 5 port is very fast ether way u can't go wrong.
T. Nicholson
Murnan Modified Motors
Matrix Tires
Serpent, 748tq
bluer322 is offline   Reply With Quote
Old 12-23-2008, 02:31 PM   #4
Trader Rating: 61 (100%+)
.21=fuel milage
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 12-23-2008, 03:30 PM   #5
Tree's Avatar
Send a message via ICQ to Tree
The 5 port turbo works well in truggy. It has plenty of bottom end torque and good top end . You will definately be pleased with the 5 port.
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 12-23-2008, 03:40 PM   #6
drs92's Avatar
the track is now moving to holland speedway, so its getting bigger along with quality
Old 12-23-2008, 03:52 PM   #7
mugenb46's Avatar
.21 5 port turbo, trust me use a 2060 or JP3 pipe and hang on.
Brian Carey
Pro Twister Mods
brian@protwistermods.com
615-838-5373
mugenb46 is offline   Reply With Quote
Old 12-23-2008, 04:04 PM   #8
drs92's Avatar
Ok cool what dynamite pipe....086? And what is the current generation out and they dont have carb problems right??
Old 12-23-2008, 04:19 PM   #9
mugenb46's Avatar
with your new track being bigger, you may get away with that, the 5 has tons of bottom , or you can run a longer header with the 086, i always used topend pipes on the GO's they where modded but topend pipes made them easy to drive. The carbs should be pretty solid, use a 6 or 6.5 carb insert and you will get great runtimes with it as well, we use P3 plugs for breakin, and run the same for racing unless you want better runtime use a P6, it will smooth out the bottom some but that may be good. Good luck
Brian Carey
Pro Twister Mods
615-838-5373
Old 12-23-2008, 04:51 PM   #10
Trader Rating: 47 (100%+)
I think you should get both and while your at it,
get a .21 7port also. Just make shure that you
get PTM (Brian) to mod all of them for ya. That
way they will have even more power and get
better run times. Ha! Ha! All the GO motors that
Brian modded for me are still running great.
rageworks is offline   Reply With Quote
Old 12-23-2008, 05:13 PM   #11
drs92's Avatar
I got a question, how come alot of people are using 7 ports in truggies...thats all i see on youtube
Old 12-23-2008, 05:18 PM   #12
bluer322's Avatar
More top end, bigger track
T. Nicholson
Matrix Tires
Serpent, 748tq
Old 12-23-2008, 05:27 PM   #13
drs92's Avatar
not enough bottom for a truggy? jw...because i always see the 7 port go's n truggies
Old 12-23-2008, 06:01 PM   #14
i have run a 7port standard in my old jammin x1 ...works like rosco ....use a 053 pipe on it ...super smooth ...but not as much bottom as the 5 ...i have also ran a 3port-r in the same x1 ...very very nice motor for a truggy ...run an 086 pipe ...the 7 port is best on a buggy ...but still works great on the truggies ....inmho
LATER COOKIE
TEAM PROLINE-RACING
Old 12-23-2008, 09:30 PM   #15
CmdGrimlock's Avatar
Send a message via MSN to CmdGrimlock
/edit, soz, wrong thread ... haha.
[SIZE="1"][b]* HPI Baja 5B RTR 2.0[/b] [color=blue]::[/color] Hopin' It Up!!! [color=blue]::[/color] [url=http://www.rctech.net/forum/oval-larger-scales-more/285144-knock-knock-whos-there-baja-pieces-arrive.html#post5599536]Build and HopUp Thread - Come Say Hi![/url] :)
[b]* Mugen Seiki MBX5T [/b][color=blue]::[/color] GO Racing .21 7 Port :: GO Femca 8081 Pipe [color=blue]::[/color] Thanks to [url=http://www.rchobbyzone.com.au/Home.php]RCHobbyZone[/url] :sneaky:
[b]* Hyper 8 PRO [/b][color=blue]::[/color] OS-30VG :: TT Tuned Pipe :tire: - I think I might sell it :D
[b]* JR XS3 Radio[/b] [color=blue]::[/color] Needing More Receivers! :( (JR-310 27Mhz incase you wanna know)
[/SIZE]
CmdGrimlock is offline   Reply With Quote
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15106 06-26-2017 04:07 AM
vintage collectors joelthedriftboy Electric On-Road 100 08-07-2009 06:39 PM
a lil engine help RACE MAN Nitro Off-Road 23 04-15-2009 04:23 PM
wants a good truggy motor that wont break the bank dgdcustoms Nitro Off-Road 72 02-21-2009 09:34 PM
Looking for a new .21 engine for offroad buggy. supralative Nitro Off-Road 54 07-31-2008 02:06 AM
Aarcmcc Rules TrustMe Australian Racing 43 10-10-2005 01:15 AM
