Old 02-20-2009, 10:43 AM   #106
Maximo's Avatar
Originally Posted by Jaz240 View Post
I have taken it apart as did you, and tried several plugs..the only one that seats, and seals properly is the Picco.. I Think The reason the OS plugs work is because they are so damn hot.
Another thing I have found is the Picco plugs have a great lifespan, even in my strung out modded engines....one of my drivers was trying the cheaper Racers Edge plugs and ended up losing a motor due to a dropped coil, sme thing happened with a OD plug, now I refuse to modify anyone a Picco unless they promise to run only Picco plugs... Also I found the OD plugs lost much of the crispness we get from the Picco plugs....however the OS plugs seem to make great power as the Team jammin guys engines were ripping very good with them....
Maximo is offline   Reply With Quote
Old 02-23-2009, 06:46 AM   #107
Any one know if a .21 piston and sleeve will fit in the .28 case? I was running a JPX .28 and a JP-2 pipe this weekend and it was a little more than i can handle. It also was using alot of fuel.
-steve
stevef is offline   Reply With Quote
Old 02-23-2009, 07:23 AM   #108
Jaz240's Avatar
Trader Rating: 52 (100%+)
Switch to the Ofna 2027 pipe, with a double bent manifold, and a 7MM restrictor.
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 02-23-2009, 03:49 PM   #109
thanks for the quick reply. was running the JP-2 pipe because it seemed to lessen the low end power and make it more drivable off of a corner. I was also using loose clutch springs for the same reason. After a warm up at the race i was at, i would fill the tank and get approximately 6 minutes and the tank was very low after than. It seems i should be getting more. I see the 2027 pipe is supposed to get good mileage, how much do you think it will improve my runtime? any idea on what it will do to the powercurve? On a previous engine i ran a restictor and it didnt seem to limit power much but it really seemed to limit the rpm it could achieve. Is this something that you feel with help the fuel mileage, and also tame the motor? or just give me better mileage?
-steve
Old 03-01-2009, 01:36 PM   #110
Suspended
does anyone know if the jammin motor uses the same carb as the picco? I heard the picco had many problems with carb leak. any info? thanks
rcflgator is offline   Reply With Quote
Old 03-01-2009, 01:52 PM   #111
Jaz240's Avatar
Jammin carbs are better carbon..no issues...but they do fit the Picco engine, and Vica-versa
Old 03-01-2009, 03:47 PM   #112
Someone knows how many shims is ideal to use with a 30% Byron? and how many shims came out off the box? Can I use the motor how it cames out off the box with 30% fuel?
triloya is offline   Reply With Quote
Old 03-01-2009, 06:56 PM   #113
Jaz240's Avatar
Stock form is fine for 30%. Break it in with 20% though..Byrons Rocks!!!
Old 03-02-2009, 09:19 AM   #114
Thank you...
I will do a heat cycle break in...why do you tell that break in with the 20% is better? It is easy to up the temp with 20%?
Thank you again
Old 03-02-2009, 09:33 AM   #115
Jaz240's Avatar
Thank you...
Thank you again
That's what was recommended by Jammin/Picco in the manual for the engine...who am I to argue with the people who make the engine?
Old 03-02-2009, 09:48 AM   #116
KKKK...you are right...completely...
Thank you...
Old 03-03-2009, 11:25 AM   #117
Integra's Avatar
they also recommend OS plugs.....so i can stand to make an argument even with THE man who's name is on the motor......he didn't have an answer for a leaky deaky .21 that had OS plugs stretched into place...he said the button seal must be leaking.
either way...the picco carbs are the same as the Jammin...they all Suck...i was told this weekend by a veteran racer that OS VG's drop right into place when you remove the alum sleeve....i might go down that road in the near future for ease of my conciseness that my carb isnt gonna lock up Or have to get DQ'd due to not being able to have even the loosest of carb return spring/band.(dont ask)
Old 03-03-2009, 11:30 AM   #118
Trader Rating: 36 (100%+)
Personally, I always run my engines in with the fuel I'm gonna race with. You're gonna hafta re-tune once you switch anyway, so why go through that hassle. Also, the extra expense...not much point in that IMO.
NitroOB4You is offline   Reply With Quote
Old 03-03-2009, 12:13 PM   #119
Integra's Avatar
some Race blend fuel's have Significantly less oil....and will not provide enough lube for the initial break in....i buy a gallon and it lasts at least 4-5 motor's....pointless i think not.
Old 03-03-2009, 12:36 PM   #120
Jaz240's Avatar
Since this has now turned into a discussion..My manual says use only genuine Picco glow plugs....I have never spoken with Jay, but I have had a few conversations with Maximo through PM's when I was considering buying one of his jammin mods. ( I bought stock instead) In my book, I would think Maximo to be the expert on these engines..He told me the composites used in the jammin carbs are better than the composites in the picco carbs, which Is where I got my info from when people ask me why buy the jammin over the Picco but hey, what the hell do I know........
Team Terribles Thread "TTT" Jaz240 Team Terribles 3938 09-04-2015 06:14 AM
JAMMIN X2 CRT!!!! luis carballo Nitro Off-Road 1009 02-07-2015 02:53 PM
Picco P7 Evo 2 brianhatesnitro Nitro Off-Road 247 02-07-2010 02:18 PM
