Old 01-27-2009, 09:53 PM   #46
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
when i got my JPX.21 the first thing i did was took the head off take one shim out because i'm running 20%, ok now 3gallons into engine decided to to clean it up, i notice it was two shims stuck together my question is how many shims should i run or is it was a mistake that ofna put 3shims on the motor?
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 01-27-2009, 10:12 PM   #47
Maximo's Avatar
they usually come with 3 shims, 2 thick, one thin.....
Maximo is offline   Reply With Quote
Old 01-27-2009, 10:34 PM   #48
bobbyblaze's Avatar
ok with that saying how many shims do i need to run with 20% nitro
Old 01-28-2009, 12:32 AM   #49
Maximo's Avatar
I would run 2 thick shims for 20%
Old 01-28-2009, 12:19 PM   #50
jamminbce's Avatar
Default jammin 21
+1 no shims needed for 30%, unless you like your motors slower than they should be
Jammin x2.5
OS v-spec hybrid
jammin x1-cr
go-7pt 086
jamminbce is offline   Reply With Quote
Old 01-28-2009, 07:27 PM   #51
Send a message via Yahoo to windellmc
I had some detonation on my first JPX running 30% without adding a shim. I added a thin shim to that one and a new JPX. They both run like a scalded dog. So I would say maybe add the shim if you want to be on the safe side. I do not think you will lose any performance.
The most important thing I have seen with these engines is the carbs have to be sealed where the aluminum and plastic meet. I also seal the pinch bolt and the banjo fitting.
MP9 tki4
Truggy?
windellmc is offline   Reply With Quote
Old 01-29-2009, 05:29 PM   #52
Default Glow plug
What glow plug works great with the JPX .21 and 30% Byron? Os P3 or the P4 works better?
Thanks guys
triloya is offline   Reply With Quote
Old 01-29-2009, 06:14 PM   #53
Integra's Avatar
Thanks guys
Neither...OFNA/Picco plugs is what you want to run...med or hot your choice.
Old 01-30-2009, 11:05 AM   #54
Ok...thanks
Old 02-02-2009, 05:29 AM   #55
Im running the JPX .28. Anyone know if a ninja glow plug will fit in there?
-Steve
stevef is offline   Reply With Quote
Old 02-02-2009, 06:31 AM   #56
Integra's Avatar
-Steve
Nope...Ofna or Picco will be your best bet.
Old 02-02-2009, 11:25 AM   #57
thanks, i didnt think it would but my local hobby store insisted it was fine.
Old 02-02-2009, 12:39 PM   #58
Maximo's Avatar
its not worth the hassles to run anything but genuine Picco plugs....some other plugs may work, but nothing fits and works as nice as the plugs designed for the engine...
Old 02-02-2009, 04:59 PM   #59
Wow...only Ofna/ Picco plugs?
The both (Amain and Carolinas) talk about safe use OS P3 and P4
http://www.amainhobbies.com/product_...ducts_id/11200
http://www.carolinasrc.com/Webstore/...idcategory=650
Are they wrong? Whats the diference betwen the OS and the Ofna plugs?
Thanks again
Old 02-02-2009, 05:07 PM   #60
Im pretty sure that OS and picco have a different taper on the bottom of thier turbo plugs.
Team Terribles Thread "TTT" Jaz240 Team Terribles 3938 09-04-2015 06:14 AM
JAMMIN X2 CRT!!!! luis carballo Nitro Off-Road 1009 02-07-2015 02:53 PM
Picco P7 Evo 2 brianhatesnitro Nitro Off-Road 247 02-07-2010 02:18 PM
