Old 12-23-2008, 06:30 PM   #16
Jaz240's Avatar
Trader Rating: 52 (100%+)
Originally Posted by mracer View Post
Who makes the 053?
Ofna, and Dynamite have versions U wont be sorry...use a double bent manifold like this ] not the half moon like this ) The two bends in the manifold help smooth out the power, and also give you more bottom end. The jammin is a 5 + 2 port so its a top end engine, you want to tame it a bit, that's where the manifold and the pipe come in, it will also give you a full minute if not more in your run times, if you go from any JP pipe to the 053 you might get 2 minutes more runtime and that's huge!!
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 12-23-2008, 06:35 PM   #17
karnao's Avatar
Originally Posted by itsshemp View Post
Funny ya ask.....
I have a little experience with them. I have been using a friends used one, as a back up, since my GRP has seen its day finally.
I really like the Jammin 21. It has gobb's of power, pretty much all over. It's not as smooth as my GRP, thats for sure, but it rockets around. It has power all over, but may take a little getting used to the delivery.
I am going to be buying this used one, for a back up, and looking into buying a new one to use as my race engine. For the price, you simply cannot beat it.
I know there are stories out there that they have carb issues, bearings go out quick, yada yada yada... but I have other friends that have ran these, and they have not had those problems. I know the one that I am using now, has not had any of those issues, so its hard to say. It could just be how you take care of it. This one has been taken care of, and it has plenty of fuel though it.
MY opinion is that in this price range, this one is at the top of my list. The only others I find interesting is the GRP (Non Tuned), and the Sirio engine. Once you get in the 300.00 range, you may as well look at the GRP (Tuned- an Awsome engine!), and plenty of the others.
Originally Posted by stipres View Post
heeltoe...itsshemp is the one i am talking about who is "supposedly" buying my motor. he actually is saying the same thing i told you and i didn't even talk to him before these post. this actually works pretty good for you because you have a couple of opinions from someone who has been doing this for awhile and some who has about a year under his belt.
funny thing!
stipres itsshemp and i race together every saturday...this weekend i hadx some engine troubles soooo i use the motor that itsshemp is "supposedly" buying from stipres.. i pretty much loved it. im still a "beginner" and i made my first 3rd place finish using this "back up" motor. one of my personal best nights, and it was the first time i had this motor in my car.
for the money...im thinking when the time comes i'd buy one
thanks pres for "selling" it to danny
thanks danny for lending it to me at the last minute
karnao is offline   Reply With Quote
Old 12-23-2008, 06:38 PM   #18
Trader Rating: 42 (100%+)
When I first started I had a JP-3 with a .28. I could go 7.5 and that was about all. I got an OS 2060 and a 2050, and have gone 12 in a truggy with a speed. I will check into that pipe. Thanks for the info.
On-point/ EA horsey power/XFactory / Hudy / Tekin / Trinity / KO Propo / Reino's Ragu
mracer is offline   Reply With Quote
Old 12-23-2008, 06:52 PM   #19
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
Originally Posted by -R2- View Post
My combo with the Jammin .21 is a JP-2 I had a JP-3 on it last week and had way too much torque, my engine has so much spank on it I've geared up and mellowed it out with the JP-2 it has several runs on it and in some cases has overheated due to a bad tank and is still running.
hey R2 your engine ran overheated because of a bad fuel tank?
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 12-23-2008, 06:57 PM   #20
Prob sucking air - went lean
Old 12-23-2008, 07:07 PM   #21
bobbyblaze's Avatar
reason i ask i think i'm having that same problem with my x2
Old 12-23-2008, 07:14 PM   #22
If the tank is leaking, they can/will suck air. This causes the engine to go lean and get hot. Do you know how to check for leaks in the tank?
Old 12-23-2008, 07:21 PM   #23
Maximo's Avatar
JPX 21 rocks using a 086... very good runtimes and more overall power then a JP4.. Another pipe of interest is the MSR 1005 ! IMO the JPX/P7R engines have huge bottom end power even with a 086 pipe...
Maximo is offline   Reply With Quote
Old 12-23-2008, 07:32 PM   #24
bobbyblaze's Avatar
refresh me if you don't mind
Old 12-23-2008, 07:35 PM   #25
Integra's Avatar
I liked the 086 over all the pipe's ive tried.....053, Jp3-4,1005
Old 12-23-2008, 08:03 PM   #26
underway's Avatar
Trader Rating: 48 (100%+)
the only issue I found with the Picco was one of the carbs on my jammin engine was bad. the slide would stick, no matter what i did to it. but the engine made unbelievable power.I pulled the p/s/r and crank from that engine an keep it as a backup for when my p7r needs parts. Great motors that are underated. Get the Jammin or a P7r you wont regret it...
underway is offline   Reply With Quote
Old 12-23-2008, 08:33 PM   #27
The quickest "trackside" way to do it is to put a fuel line from the fuel outlet to the pressure (exhaust in), fill the tank 100% full, then gently squeeze the sides of the tank. Usually, if there is a leak, fuel will come out where the leak is. This is a method I have used at the track and it has always worked for me.
Hope this helps.
Old 12-23-2008, 09:59 PM   #28
bobbyblaze's Avatar
Hope this helps.
ok i check there are no leaks, but i notice the fuel line is alittle smaller than i usually run.. think if i go to a bigger fuel line will help ?
Old 12-23-2008, 10:33 PM   #29
Possibly. Make sure you don't have holes in the line and the engine is not leaking....
Old 01-01-2009, 04:55 PM   #30
Triton3d's Avatar
Trader Rating: 17 (100%+)
Hey guys, need some help with this motor, my motor is boging real bad when i hit the throtle, im using a JP2 pipe and Sidewinder 30% gas, ive played with the low needle but nothing, today i ran it and i saw the carb wet, im going to check for leaks, would it be the pipe?? would a 053 help??
Mike
Triton3d is offline   Reply With Quote
Team Terribles Thread "TTT" Jaz240 Team Terribles 3938 09-04-2015 06:14 AM
JAMMIN X2 CRT!!!! luis carballo Nitro Off-Road 1009 02-07-2015 02:53 PM
Picco P7 Evo 2 brianhatesnitro Nitro Off-Road 247 02-07-2010 02:18 PM
