Old 12-20-2008, 09:36 PM   #1
CaptCrunch's Avatar
Trader Rating: 17 (100%+)
Default Nitro Engine rebuilding
Howdy folks, I have a couple questions about engine rebuilding.
I've gotten a couple of engines on used buggies/truggies that have qustionable compression. Can I bring these engines back to life by simply changing the piston/sleeve and bearings? The cranks on both engines look smooth with zero scoring, and the head buttons look like they are in perfect shape. Neither will pass the gravity test though, so I was considering putting a new sleeve, piston and bearings on both engines. One is an Ofna Picco 27 wich I gather is a pretty cheap engine. The other is a GS B01 .21, that I understand from talking to a few people was a pretty good engine in it's day.
Are there any other things that I need to look at before deciding to rebuild these engines? And is there anything else that should be replaced at the same time?
I don't have any nitro engine rebuilding experience, but I have built/rebuilt everything from from a lawnmower engine to the custom 502ci engine in my speedboat, so I should be able to handle the technical aspects.
Any input from you engine guru's would be greatly appreciated.
Thanks,
Kris
Never met an RC I couldn't crunch! If it never breaks, you're not playing hard enough.
Current Toys: 1990 RC10 Gold Pan buggy, 1991 RC10 Team Buggy, AE TC3, Diggity Designs XLR8, Tamiya TRF 415, Losi Mini Late Model, Losi Mini Slider, AE RC18MT, 2 Jammin X1X CR's, 2 Jammin X1 CRT Pro's, HPI Savage XL, Revo Platinum, Jammin X2 CR Electric Conversion, 4X2 Slash, 4X4 Slash, Losi Comp Crawler, Arrow Shark 47" Boat, Blade 400 Heli, Blade CX3
CaptCrunch is offline   Reply With Quote
Old 12-20-2008, 09:41 PM   #2
JAMMINKRAZY's Avatar
Yes all you would heve to do is change piston/sleeve/rod and bearings to get them back to spec. Either that or get them pinched. Depending on the price of the motors and the price of parts for them it might not be worth it to replace those parts. A pinch can be gotten for fairly cheap and if everything else in the engines is in working order you could get them to last 3-5 more gallons.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 12-20-2008, 09:43 PM   #3
yeaklet4's Avatar
Trader Rating: 34 (97%+)
the gs bo1 is nice not the fastest but run so good i have 6 gallons of racing on mine and never opened it up then i sold it and they beat the hell out of it and is still running. i bet a good port job wood make that motor mean.
yeaklet4 is offline   Reply With Quote
Old 12-20-2008, 09:48 PM   #4
Trader Rating: 1 (60%+)
well u can send them in and have them pinched. u want to replace the rods. they tend to wear out after the engine loose compression. i'll look up where to send the piston and sleeve into. if u want me to. thanks nate
mungen is offline   Reply With Quote
Old 12-20-2008, 09:55 PM   #5
yeaklet4's Avatar
os rocket
propinch
ray racing
and a dude on here 22racer
Old 12-20-2008, 10:24 PM   #6
chunk t's Avatar
Kris,
whether you get a pinch or fresh P&S, definately replace the bearings; they're cheep. Inspect the piston face and look for pitting and cracking (this is more likely to be seen on the outer edge). Do the same with the head and check the squish band. If the piston face or squish band looks rough, or bad in any way, the rod, wrist-pin & bearings have had a hard life and should be replaced. Other wise keep the old rod & pin (they're broken in.. not broken). I would also suggest measuring the roundness of the crank pin. if the differance between high and low is greater than 10%, replace the crank. (this is also a good way to judge the number of hours on the engine).
If you really want to get into the nitty-gritty, take some measurements while the engine is in pieces. This information will help you set your pipe length accurately and know what kind of performance the engine is tuned for.
Oh yeah, how did you check the compression?
chunk
chunk t is offline   Reply With Quote
Old 12-20-2008, 10:39 PM   #7
22Racer's Avatar
Trader Rating: 67 (100%+)
Here's a link to my thread. I don't agree with changing bearings, only if the need to be changed.
http://www.rctech.net/forum/nitro-of...ebuilding.html
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 12-20-2008, 11:15 PM   #8
CaptCrunch's Avatar
Thanks for the info guys.
Both of the engine's squish bands look great. There is zero noticable pitting, cracks or scratches on the pistons, cylinder walls or the combustion chamber in the heads. The top of the pistons look clean with almost no discoloration, and the cylinder walls look smooth with only a slight change in shade showing the top of the piston travel.
Chunk - I'll go ahead and mic the crank pin (Hoping the crank is still good). But I'm totally confused as to what you mean by taking measurements helping me set the pipe length accurately and knowing the performence that the engine is tuned for. What exactly do you mean by that? Thinking of automotive engines, I understand how knowing the exact displacement and the volume of the combustion chamber will help determine the overall compression of an engine, but how does this relate to a nitro engine?
At this point I'm thinking that the Ofna engine might only warrent a pinch and a new set of bearings, while the GS B01 will get a new sleeve and piston as well as bearings.
I just want to do this right and end up with functional engines and not a huge headache instead.
Once I either pinch or replace the sleeve/piston, will I need to do a complete break-in as if they were new?
Thanks for the help,
Kris
Old 12-21-2008, 10:28 AM   #9
yes u will have to break them in again.
Old 12-21-2008, 02:37 PM   #10
chunk t's Avatar
Kris,
These little nitro engines are two stroke pumps with ports in the sleeve and crank. As the piston goes up & down it changes the pressure in the crank case and in the combustion chamber. The action of the piston sliding up and down past the ports regulates the flow of fresh fuel and burnt fuel. The TIMING (duration a port is open) is one component of the larger equasion of how the engine was intended to produce it's peak power.
The exhaust system we use is actually a combination of a header and a tuned resonance chamber (Pipe as we like to call it). The header aids in removing burnt gasses and pullining in extra fresh charge; this is called scavanging. The PIPE reflects the impuse after it has travelled through the header, back into the header & ultimately the exhaust port; this is called packing. these two actions allow the engine to burn more fuel than its actual displacement. Think of it as super charging.
An engine that effectively uses the tuned exhaust produces more power, gets better fuel efficiency and runs cooler.
Just PM me if you want to know more specifics.
chuck
Old 12-21-2008, 05:47 PM   #11
Can someone please explain the gravity test?
herb99 is offline   Reply With Quote
Old 12-21-2008, 06:06 PM   #12
CaptCrunch's Avatar
Chunk, you have a PM.
Herb, the way it was explained to me, if you hold the engine by the flywheel at a 90 degree angle right as it is heading into the compression cycle, the compression should be able to hold it sideways for at least 10 seconds before the weight overcomes the compression and the engine falls downward.
Folks please correct me if I'm wrong.
Kris
Old 12-21-2008, 07:59 PM   #13
22Racer's Avatar
With a new piston and sleeve you will need to break it in. Some people that pinch motors do them pretty tight and you will need to rebreak in. When I pinch a sleeve I try to get it about like a motor after a gallon on it. There is no need to get it as tight as it was new as it has already worn in as a set. I only recommend a couple tanks 2 hours richer.
Rex
Old 12-21-2008, 08:25 PM   #14
Nitroburner9's Avatar
How exactly do you pinch the motor?
Nitroburner9 is offline   Reply With Quote
Old 12-21-2008, 11:53 PM   #15
houston's Avatar
Trader Rating: 91 (100%+)
how come all the sudden there is a bunch of guys trying to advertise that they will work on your engines , (not just you rex) but holy smokes there are about 8 guys that are trying to get you to send them your engine .
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Motor Pinched?? Triton3d Nitro Off-Road 15 01-23-2009 09:10 PM
5 cell in 27t/19t MR JOLLY Electric On-Road 451 03-15-2007 09:12 AM
Fantom Engine Manual = ABC Engine Bible Horatio Monster Trucks 9 02-05-2007 07:35 AM
Flywheel, spur gear, air flow and other questions alucard13 Nitro On-Road 9 03-28-2003 04:29 AM
MT12 RS12 RB12 and other engines tuning tips disaster999 Nitro On-Road 60 10-15-2001 09:38 AM
