os rg .21 what pipe
os rg .21 what pipe
what would be a good pipe for a bigger track im looking at the ofna jp pipe line.
The OS 2030 pipe is made for the RG.
Tony
Tony
I ran the Nova 086 pipe with short header and it was ballistic up to a 110' straight. If its a bigger track just put a 14 tooth CB on and it will run with the best of them.
what kind of temps does this motor run good it is slighty moded and has the nova head on it
also whats a good plug for this
with my rg i ran a mc59 plug. and a os2050 pipe
so these are hot plugs right. when i was running 1/8 buggy i was always running mccoy 9's nevver had a problem so whats the big diff from hot to cold plugs.
just for everyone to know about mc59 plugs. i ran 2 head shims and got 8 gallons out of it.
O. S. A3 plug runs great in that engine with 30%. RG runs a little hot with the stock head (250'ish). You'll have to be careful with the aftermarket head b/c it will cool much better. Tune from rich to lean and make sure you have smoke throughout the powerband and you'll be all right. I use a JP-1 with mine on short tracks, but JP-2 is probably a better choice on a little bigger track if you're sticking with the Jammin pipes.
is the a3 a cold plug
so what are the pro's and con's of hot and cold plugs for this motor
