Old 12-20-2008, 08:52 AM   #1
Thumbs up FIORONI TRACTIVE DIFF
anyone tryed them, is it worth buying them, cause they are realy expencive one? I just need more on power steering in the front of my AE-rc8truggy.
ANDRAZ is offline   Reply With Quote
Old 12-20-2008, 09:54 AM   #2
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
there are a quite a few threads on here concerning these diffs.. just us the search tool and you will find plenty of info
jamminnay is offline   Reply With Quote
Old 12-20-2008, 03:30 PM   #3
K_B
K_B's Avatar
Trader Rating: 69 (100%+)
Spending 200-something on a diff might get you more on-power steering, but reading this will get you more on-power steering for alot cheaper
http://www.teamxray.com/teamxray/sho...p?file_id=4461
K_B is offline   Reply With Quote
Old 12-20-2008, 06:19 PM   #4
I have all three diffs. They do work!!! I only use one or two at a time. They are meant to be a tuning aid. You are NOT supposed to use all three. I would try the front and center to begin with. I use the center alot and I use the front on certain tracks. They are simple to maintain.
If you do get them, take the 4 main bolts out and clean them with Nitro spray or carb cleaner then Red Loctite. If you try to run the diffs without doing this, the bolts will come loose and so will the ring gear. Good Luck
SPEEDSKI is offline   Reply With Quote
Old 12-21-2008, 12:34 AM   #5
SPEEDSKI, yes I was thinking getting front end center, not the rear one. Last year I tryed front active diff in my previous truck Xray xt8, and it worked great-but the xray diffs are much cheaper, so I was thinking getting some fioronis diffs for my rc8t. i know fioroni diffs has only 48 spur gear available for center asso, so Ill have some CNC work to do with it-I need at least 50t spur gear.
Thanks for replys to all.
Old 12-21-2008, 03:08 AM   #6
vladconnery's Avatar
Trader Rating: 35 (100%+)
+1 Great Post
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Losi Smart Diff Frank L Nitro Off-Road 580 06-25-2013 11:01 AM
Adam Drake talks about the new 8ight 2.0 Sylvain Nitro Off-Road 545 05-30-2010 05:57 PM
$225 for a diff? Seriously? Don Duct Nitro Off-Road 69 10-15-2008 04:33 AM
