Old 12-18-2008, 02:25 PM   #16
Trader Rating: 1 (60%+)
running a cold plug for me is my engines last a long time and are easer to tune. with hot plugs the engines run hotter around 260-280 with it not running lean.
bought a ninja before we started racing this year and i'm running a cold plug in it and it has 4 gallons on it and it still tight. my $.25 worth.
mungen is offline   Reply With Quote
Old 12-18-2008, 02:29 PM   #17
Davidka's Avatar
Trader Rating: 75 (100%+)
I like A5's (med-cold, like an MC-8) and either 086 or Jp2 pipe. I didn't like the #8 as much with 30%, wasn't crisp on top.
Old 12-18-2008, 04:22 PM   #18
yeaklet4's Avatar
Trader Rating: 34 (97%+)
is there a power diff's from a hot plug to a cold plug
yeaklet4 is offline   Reply With Quote
Old 12-18-2008, 04:33 PM   #19
not really
Old 12-19-2008, 07:05 AM   #20
Plug temp and shimming are how you change the timing on your engine. Not so much about more or less power but where the power's delivered. Both the A3 and A5 will work in that engine, the stock shimming is fine for 30%. Try both and see which works best for you.
cjtamu is offline   Reply With Quote
Old 12-20-2008, 03:48 PM   #21
yeaklet4's Avatar
how many shims for 20% nitro
Old 12-20-2008, 04:48 PM   #22
i'd use one shim for 20% fuel and 2 for 30%. never had a problem with it.
Old 12-20-2008, 04:53 PM   #23
yeaklet4's Avatar
what would happen if ya used 2 for 20%
Old 12-20-2008, 05:02 PM   #24
2 shims has less compression than one shim.
Old 12-20-2008, 08:24 PM   #25
Trader Rating: 14 (100%+)
i just got a used rg. i would like to know the base needle settings for this engine, thank you.
meno222 is offline   Reply With Quote
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15106 06-26-2017 04:07 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
Sirio engines thread EVOLUTION Offroad Nitro Engine Forum 2824 04-29-2014 10:58 AM
New to 1/8th Nitro, which .21 engine/pipe should i get??? mikezap Rookie Zone 12 02-07-2007 02:51 AM
F/S;GS RACING CL-1 STUFF & ENGINES ETC. Cl - 1 Brodie R/C Items: For Sale/Trade 57 10-25-2006 04:10 PM
Pipe for OS .21 RG? SeattleRCer Electric Off-Road 9 09-13-2005 08:22 PM
