Help - clutch nut came loose while clutchbell attached
Here is a brain teaser, I hope someone can come up with an answer for me
Somehow the clutch nut came loose from the pilot shaft while the clutchbell is still installed. I cannot loosen the screw at the end of the clutchbell because the flywheel no longer holds the pilot shaft.
Short of using something to block the piston is there any way to get resistance on the pilot shaft in order to get the outer screw loose? I'd hate to have to take a dremel to it, it would probably ruin the clutchbell too.
The situation you're describing would be a perfect application of this tool: http://www.amainhobbies.com/product_...oducts_id/8459
pistion lock tool
http://www.amainhobbies.com/product_...oducts_id/5333
how does that thing work Rob?
If you want a tool to hold the flywheel for tightening, use a tool like this:
http://edsracingproducts.com/FLYWHEE...B000XAKIIG.htm
I do not recommend any tool that holds the piston to tighten a flywheel nut, as many manufacturers will deny any kind of warranty on the motor if any damage to the piston or internals is found. Clutch nuts need to be tighten correctly and piston lockers can dent pistons with this amount of torque. The O.S. tool maybe, but I still don't like them.
tool
I use just a small, i mean small dot of blue threadlock on the pilot shaft threads, that way you dont have to get the flywheel nut super tight. I just get it as tight as i can while holding the flywheel with my hand. Never, ever had one come loose.
I wouldnt trust a piston locker personally. If I have trouble with the engine turning over while tightening the clutch nut I just use a big zip tie. Double it over ant put it into the exhaust port as ezveedub said and then tighten or loosten it that way. I have seen some rubber tipped piston lockers but I still wouldnt trust them. You can mess up your piston real easy with them. With the zip tie it would break before hurting the piston.
there is one other option as well. YOu can put the piston at BDC and then add quite a bit of after run oil, i mean like liberal amount through the glow hole, then put the plug back in, then turn the motor up sidedown and the oil will travel into the cylinder, and we all know you cant compress fluid, so run it against the fluid and it basically hydraulics the motor, bust your screw loose or whatever, then pull the glow plug, run it over on your starter box, and its ready to rip again.
