Old 12-16-2008, 04:49 PM   #16
Integra's Avatar
Originally Posted by JAMMINKRAZY View Post
I wouldnt trust a piston locker personally. If I have trouble with the engine turning over while tightening the clutch nut I just use a big zip tie. Double it over ant put it into the exhaust port as ezveedub said and then tighten or loosten it that way. I have seen some rubber tipped piston lockers but I still wouldnt trust them. You can mess up your piston real easy with them. With the zip tie it would break before hurting the piston.
X2
Old 12-16-2008, 07:43 PM   #17
Trader Rating: 47 (100%+)
You could also pull the carb and slide a plastic
or hardwood dowel into the crank port. This
would also keep you from putting any preasure
on the con rod and piston.
rageworks is offline   Reply With Quote
Old 12-16-2008, 08:11 PM   #18
RacerScott's Avatar
http://www.carolinasrc.com/Webstore/...s/prodList.asp
this tool is your best bet, plus use a small drop of blue locktite.
VP powermaster fuel | Upgrade RC
Scott U.
RacerScott is offline   Reply With Quote
Old 12-16-2008, 08:14 PM   #19
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
I don't think your link is working????
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 12-16-2008, 09:17 PM   #20
Originally Posted by jaylude22 View Post
The situation you're describing would be a perfect application of this tool: http://www.amainhobbies.com/product_...oducts_id/8459
That is a fantastic little tool, makes things soooo much easier.
8ight pro Kit, MassiveMods stage 5 modified MRT GRP .21
Jonro is offline   Reply With Quote
Old 12-17-2008, 06:29 AM   #21
cdbias's Avatar
Piston locker for turbo style motors:
http://www.integy.com/cgi-bin/webc.c...637&p_catid=11
Not sure that I would use one. It's metal on metal inside the motor. Can't be good regardless of what people say.
I use zip ties or even easier just shove the back end of one of your cleaning brushes into the exhaust port. Don't even have to remove the glow plug.
Thank You,
Casey Bias
Tekno RC | Jconcepts| Trinity | Hobbywing | MKS Servos | Elevation Sports | Code 3 RC |
cdbias is offline   Reply With Quote
Old 12-17-2008, 02:01 PM   #22
bajaracer1501's Avatar
I got one of those Integy turbo piston stops last week and will never use it again. It did not thread in & out smoothly at all.
bajaracer1501 is offline   Reply With Quote
Old 12-17-2008, 02:31 PM   #23
robbdny's Avatar
Trader Rating: 19 (95%+)
Default casey
From now on I am mimicking CDBIAS, "Casey Bias." this guy is always blazing fast!! The whole group of guys he runs with is a good crew.
robbdny is offline   Reply With Quote
