Old 12-15-2008, 11:53 PM   #16
MaTt 93's Avatar
Send a message via MSN to MaTt 93
ok thanks again for the help
I'll pull it apart this weekend and give it a good cleanout.
thanks again
TLR 22 - Spektrum - 7.5 Speed Passion V3 - LRP
Durango DEX410R - Spektum - 5.5 Speed Passion V3 - LRP
SECOND PLACE IS THE FIRST LOOSER !!
MaTt 93 is offline   Reply With Quote
Old 12-16-2008, 12:10 AM   #17
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
No problem! Post back in here with your findings.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 01-20-2009, 11:58 PM   #18
MaTt 93's Avatar
well i finally got time to pull it apart and have a look and its all good. i'v also tried stating it but it just won't start . Oh its not burning plugs anymore either.
thanks
Matt
Old 01-21-2009, 12:09 AM   #19
losi_racer's Avatar
Trader Rating: 25 (100%+)
thanks
Matt
HEAT!HEAT!HEAT!
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 01-21-2009, 12:31 AM   #20
MaTt 93's Avatar
yeah i'v heatd it up 120 degrees celcius and it just spins around on the stater box
Old 01-21-2009, 12:43 AM   #21
TTR:EB4's Avatar
plug new? glow plug igniter charged?
The Masher! >.<
TTR:EB4 is offline   Reply With Quote
Old 01-21-2009, 01:15 AM   #22
looper's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to looper
how many volts are you feeding to the glow plug?
Looped Designs Paintwerks
http://ldpaint.webs.com/ Email: Looped.designs@gmail.com
looper is offline   Reply With Quote
Old 01-21-2009, 01:26 AM   #23
Cumbustion engines need four things to come together in order to operate.
Fuel
Air
Compression
Ignition
You shouldnt have problems with compression, in that you have to heat it up to get it to even spin over.
If your air filter is clean you shouldnt have a problem with air.
I dont care if i just pulled a fresh glow plug from its package, I always test it with a known working glow heater before i install it. If that checks out ignition is taken care of.
Fuel can be kinda tricky on these things. Of course use fresh fuel. Check and make sure you have your fuel/pressure line installed correctly. Look at the pickup in the fuel tank to make sure its not trashed. If you have a fuel filter make sure its not stopped up. If you can see fuel reaching the HSN inlet you are still not in the clear. Take carb off and give it a good cleaning and inspection, there is a good chance trash has plugged up an orfice that lets fuel through.
One last thing i just thought of. Make sure the starter box is spinning in the right direction. I dont think she will even begin to fire if your spinning it backwards.
Ive done everything Hank did but die
NCWC is offline   Reply With Quote
Old 01-21-2009, 02:21 AM   #24
MaTt 93's Avatar
ok, everything is charged and i'v got a new plug in there. There are 1.2 volts going into the plug. I'll set the carb to the settings that jpalessi suggested above and check that there are no blocks any where. I'm pretty sure that the stater box is fine because i use the same stater box with a different car and it starts fine.
thanks for the help, i'll get this engine sorted sooner or later
Old 01-21-2009, 02:44 AM   #25
I forgot something, but i hope for your sake its ok.
Since its a Vspec, give it a good visual inspection of the bottom side of the case. They can crack along the bottom usually parallel with the crankshaft. You will need good lighting and look it over like your investigating a murder scene. If you see something that looks like a crack, but your not sure, take a hobby knife and see if you can stick the balde in it. Check the whole length of the suspected crack. If the blade dont go in its probably not a crack. I know you have had the engine apart recently but ive seen alot of these cracks and they are usually not easily identified. They are usually easier to see from the inside because the black coating on the case can hide them. A crack will let pressure escape from the crankcase. Pressure that is used to force fuel upwards into the combustion chamber.
Old 01-21-2009, 04:26 AM   #26
rdcracer's Avatar
Like NCWC said it is common for people to mount the motor on the engine mounts first tight. then mount it on the frame which can stress the case and crack it. Check this as it is very common. Try taking the air cleaner off and putting a LITTLE fuel directly into the carb to see if it is a problem with the carb or fuel line/tank. Also try putting your finger over the exhaust while you try to start it to force fuel into the carb.
Good luck. These are great engines and basically trouble free
R & RC TIGHTWAD RACING
Where any price is too much.....
BMI 1/10 & 1/12 Copperhead
Scapel, Losi 22, Jammin SC10, Wraith
rdcracer is offline   Reply With Quote
Old 01-21-2009, 06:30 AM   #27
l3asher's Avatar
This was a problem on the older V Specs, but has been corrected on the new ones, correct?
l3asher is offline   Reply With Quote
