Losi 8ight 2.0 parts on 8ight-T
#31
Now I'm sure this question has been asked before and I just haven't found it yet. I know they moved the throttle servo out, but is the steering servo area any different? I'm debating about switching to the 2.0 tray, but since I already have the King Headz throttle servo brace, why would I want to change.
the tray is UBER Stiff and its almost a guarentee not to blow another servo period...imo its worth it.
#32
#33
I just bought another T 1.0 because I couldn't turn down the deal modhobby had on them so I'm planning on just adding the 2.0 tray and that's about it from the 2.0 for now. I'll pick up a 2.0 T once they are out but I still plan to keep my 1.0 as well.
So what I gathered so far from reading this about the 2.0 tray on the T 1.0 is that it "can" work but I would need to mill under the servo a tad bit for clearance and cut away the mud guard for clearance.
The 1.0 linkage will work fine and I shouldn't have any other issues right?
#34
yes yes and yes....and ill also recommend the Servo saver plastics.....as the 2.0 actually work's like a saver should.
#36
#37
The rear outer hinge pins are also good to put in and also the rear hubs if you dont want to drill the 2.0 acerman is good to have aswell. I have done all the mods to my 8-t i just gotta run it now...
#38
