Dynamite Platinum 21
Hey guys I have a Dynamite Platinum 21 motor that I am running in my D8. I was wondering if any of you guys who are running the motor have had to tune the mid range needle on it. I have as I am trying to get some bottom end out of it. What could I do to get more bottom end out of this motor? I currently am using the stock carbon clutch shoes that came with the D8 along with the stock 1.0 springs. Will aluminum clutch shoes improve the bottom end? If so what shoes do you guys recommend? Also will the aluminum shoes used for a mugen mbx5r fit , I was given a set by a close friend to try, but I haven't had time to take apart the clutch yet to see if it will fit. Oh, and I am using a losi re10 pipe with this motor.
Assuming you are not getting a lean bog, and your tune is good, you can try to trim a little off the tip of the carbon shoes, and run some 1.1 springs. Im not familiar with the Dynamite engine, but you may be able to gain some bottom end snap this way.
As for the mid setting on the carb, personally I normally leave them at the factory setting. If i mess with it at all, I never have to turn it more than a 1/2 hr in either direction. I only use it to smooth out the transition from low speeds to high, if I cant get it by using the LSN.
Someone else may have another opinion on this though.
Is it the new version engine or the old. The old version is very hard to get bottom end like a high doller engine.
I have heard the new version is better though.
Are you running the 053 pipe? If not you should be.
Predator,
The new engines is the xp model. I would use the 053 pipe with a round header. As for the bottom end like someone already stated make sure the bottom end needle isnt to lean. And for the mid range needle whatever you do dont touch that needle or you will have worse problems than you have now. What kind of temps are you running in? I would try maybe putting a dyn#3 plug in it also. This plug will make the motor easier to tune.
You can do as said earlier and trim alittle off the carbon shoes, or you can use the Mugen shoes. Mugen makes 2 kinds of alum shoes look up the part number and see if they are the regular ones or the light ones, the light ones will engage earlier which will give you more bottum end snap. But with alum shoes you will have to take the bell off after every race day and trim the " mushroom " affect off. Going to 1.1 springs with your stock shoes will also give alittle more snap. Try some scotchbrite pad on the inside of the bell to. Because you can get slippage from the bell being dirty, and spray your stock shoes with brake cleaner at the same time you clean the inside of the bell.
Predator,
On my D8 with that engine I run the 053 round header #6 plug/Nova using 2 washers..Important. Yes I adjust the mid screw. Drop the head to only 1 thin shim w/6 plug....runs better with cold plug and 1 shim. Mugen aluminums p/n CO794 using the stock HB 1.0 springs. This gave me what I was looking for. I race at Rev and it works great.
When you adjusted the midrange screw did you back it out a turn or in a turn. right now mine is about 1.5 - 2 turns in. I will definatley order the 053 pipe as that is what appears to be the correct pipe for this motor. I will run the #6 plug. As far shimming the motor I haven't even touched that I am just running it right now as it came in the box. I will try those mugen shoes too. When you say round header what do you mean? I see the 053 pipe is a dynamite pipe, but I don't understand what you say or mean about a round header.
Regarding the shoes you have it backwards. Lighter shoes engage earlier providing less snap....bogging the engine. Heavier shoes need greater rpm to get thrown out therfore they "hit" harder giving more snap.
Actually you have it backwards...heavier engages earlier, lighter engages later.....tighter spring later, softer spring earlier !
I found that with this motor it makes the most power at 200 210 degrees. And if the bottom end is lean you are going to feel as if you need more power because of lack of fuel. And if you feel like the tune is right i would mess with the clutch as you have already metioned. maybe go all aluminum shoes. Another thing i would try is different plugs! i would use a mcoy #8 or a dyn #3 or 4
