Old 12-24-2008, 04:39 AM   #31
ridgerunner1's Avatar
Trader Rating: 21 (100%+)
No damage can be done other then it running better, the HSN house just unscrews there are two washers on the housing make sure they go back in the same spots and just make sure you don't over tightin the housing when you put it back on but tight enough to stay on, let us know how it went, here is a break down of your engine.
http://www.dynamiterc.com/ProdInfo/F...220-Manual.pdf
ridgerunner1 is offline   Reply With Quote
Old 12-28-2008, 05:14 PM   #32
RC Dad's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to RC Dad
Originally Posted by gasser View Post
The best combo we have found for the Xp is the 53 pipe and Dynamite Platinum #3 plug DYNP5603.
Is that 053 pipe used with the short (round) or long (J-haped) header? I tried an 063 pipe with long header and had adequate bottom end but nothing on top.
GV2 Pro, XXX4G+, Blitz SCT, CRC GenXL
RC Dad is offline   Reply With Quote
Old 12-28-2008, 05:18 PM   #33
Ralph Walters's Avatar
Gasser is speaking of the Dynamite 053 pipe combo. It comes with the round header. Best all around pipe I have found for the XP!
Innovative Designs Racing Concepts
Ralph Walters is offline   Reply With Quote
Old 12-28-2008, 05:24 PM   #34
easyryder's Avatar
Great engine!!!!!!!!!
XRAY XB9. Rubber tires with foam inside and super glue to keep them on. Cheap, but fast radio, high dollar servos, savox, mostly.
Cheap .21 engine. Modern starter box, finally!
easyryder is offline   Reply With Quote
Old 12-28-2008, 05:47 PM   #35
Yah it is the round header. I just back from the track right now and I have to say I am liking this motor more and more. I dropped my clutch bell to a 14 tooth from a 16 tooth, and I added 2 1.1 springs on my clutch. I feel that the motor has good smooooooooooooooth bottom end now. Thank you guys for all of your help. Temps are around 230.
xpertpredator is offline   Reply With Quote
Old 04-13-2009, 12:17 AM   #36
Ok, I need some help. I have a 21 SG with a JP-4 pipe an dI am having a hell of a time getting it tuned. To start with I bought it used and it has no pinch when cold so I have ordered a new piston/liner, it was pretty cheap. I know that this is affecting my power so I am not too worried about that, but I have read different suggestions on where to start with the needles for tuning. It will have to be broken in again which I already know, but where should I start with the needles? I don't know if I have the old carb or the new. Should I just follow the manual or do some other setting. Oh I am using an OS #8 but I will try another plug if need be. Thanks for the help.
USP45 is offline   Reply With Quote
Old 04-13-2009, 07:14 AM   #37
dmatter's Avatar
Have any of you guys ever ridden a 125cc or 250cc 2-stroke with the power valves stuck open? They make absolutely no bottom end power at all. The V-Spec you mentioned is a 3 port, the XP is a 9 port, so all the tuning in the world will not find this engine any bottom end. Bottom end of story. Sell that motor to an Oval guy, they are always pinned and that Motor is perfect for that application. An Oval track is about the only place you could keep the XP in it's powerband.
dmatter is offline   Reply With Quote
Old 04-13-2009, 07:46 AM   #38
NITR04LIFE09's Avatar
I just picked this motor up and have about 10 tanks through it im running the khz alum. clutch shoes and a 13t bell on my losi 8 and have no problems with bottom end. My question is what are you guys using for after run oil i read that you cant use it because of the crank, but then in the owners manual it says to use after run oil.
NITR04LIFE09 is offline   Reply With Quote
Buy / Sell BoardSlapper Canadian R/C Scene 11025 Yesterday 08:02 PM
For sale/trade thread UnderDaHill Nebraska/Iowa Racing 5231 08-02-2017 06:11 AM
Selling Everything !!! Part 1 Briguy R/C Items: For Sale/Trade 28 07-28-2009 02:04 PM
.21 Motor???? Triton3d Nitro Off-Road 35 01-27-2009 07:57 PM
JP-3 LIST donbeatya Nitro Off-Road 23 12-31-2008 04:03 AM
Pro Twister Mods Dynamite .21 w/Dynamite MR pipeand header Dan Reino R/C Items: For Sale/Trade 18 05-16-2007 04:30 AM
