Old 06-13-2009, 07:44 AM   #61
COBRARACING's Avatar
Originally Posted by drperry View Post
Pretty much, only run a regulator if you've got servos that aren't rated for it, and have no history of working at that voltage... Unless you wanna be the lucky gambler
I'm tempted to take my CCBEC out of my truggy and go unregulated... Going to do some reading up on my throttle servo first
Just some tech any servo that runs the Fr6461 DIGITAL intergrated circuit and coreless motor can run up to 9Volts as for the receivers i dont know .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 06-13-2009, 08:30 AM   #62
Integra's Avatar
Interesting.....any more info on this particular board/motor combo ?
Old 06-14-2009, 01:26 PM   #63
vagnik's Avatar
So the problem with not using regulator is only the servos or also the receiver? Most of you refer to the servos (I use ACE servos and MX-3FHSS receiver).
Also one important to me question: When the lipo is connected directly to the regulator and the regulator is then connected to a switch (closed), does the regulator draws current? So in some days your lipo will be exhausted?
Thank you!
vagnik is offline   Reply With Quote
Old 06-14-2009, 01:33 PM   #64
drperry's Avatar
Send a message via AIM to drperry Send a message via MSN to drperry Send a message via Yahoo to drperry
Most receivers are good for LiPo voltage, but you'll have to double check, as there's some that aren't.
And you should have the regulator on the OTHER side of the switch, as it always draws current.
You should, actually, always unplug the LiPo just to be on the extra safe side...
RC18MT - Tekin FX/Stock motor
Yokomo MR-4TC SD CM Novak GTB/LRP X-11 13.5 brushless
E-Jato - Diff still unloads in corners, with 100k weight oil in it!
drperry is offline   Reply With Quote
Old 06-14-2009, 02:12 PM   #65
Integra's Avatar
X2...switch or Not UN plug your lipo when your not using it.
Old 06-15-2009, 01:00 AM   #66
I'm using a 4pk and bls351 servos and a personal transponder. do u guys think that its safe for me to use lipo 2s without a regulator?
beer is offline   Reply With Quote
Old 06-15-2009, 01:26 AM   #67
drperry's Avatar
The AMB transponders, seem to be rated for a maxiumum of 8 volts... Not sure if that extra .4 volts is going to bother it or not.
Old 06-15-2009, 01:27 AM   #68
Sam-E's Avatar
Thank you!
The regulator will draw a small amount of current if directly plugged into the lipo but it is easier to plug the lipo into the switch and switch into the regulator, no need to turn off the switch with this configuration.
TMORC - Official Club for the 1/10th Offroad Electric Worlds, 2012!!
Sam-E is offline   Reply With Quote
Old 06-15-2009, 09:39 AM   #69
up
Old 06-15-2009, 10:00 AM   #70
You have to use a regualtor in servos that are NOT HV. Spektrum receivers can handle the extra volts but ther servos can not unless it is made for HV,
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 06-15-2009, 11:15 AM   #71
pyromania's Avatar
Trader Rating: 18 (100%+)
No, you can go unregulated w/ almost any servo. Regular 5 cell packs peak at 8v so I doubt the extra .4v is really harming the servos.
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 06-15-2009, 11:26 AM   #72
Ive never understood why you would need a regulator anyway. I run electic offroad also and run a 2s 25c 4900 lipo with the same receiver and lesser quality servos than 1/8 scale. Whats the deal with that ? Can someone explain the theory of why you can run it one way but not the other ?
Making a comeback !!
roadracer43 is offline   Reply With Quote
Old 06-15-2009, 11:29 AM   #73
Ok Im not going to argue - you NEED A REGULATOR - with lipo and yes its a big difference from NHIM. I have burnt out 4 servos becuase I was told that I didnt not needs a regulator. No servo company will warrenty your servos that you have burnt out. well - to each is own
Old 06-15-2009, 11:30 AM   #74
Your ESC regulate the voltage input going into the RX
Old 06-15-2009, 02:56 PM   #75
Integra's Avatar
first of all servo's DO NOT need to be HV to take 2 cell unregulated...there are many brands and models that will accept it no problem's.....2ndly servo's will still be warrantied even if they were run on 2 cell unregulated....that's what a warranty is for....Hitec will replace a Chewed up servo a dog got a hold of....They WILL warranty a 2 cell lipo incident.
Tamiya Championship Series Neil Rabara Racing Forum 21154 Yesterday 08:55 PM
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
JAMMIN X2 CRT!!!! luis carballo Nitro Off-Road 1009 02-07-2015 02:53 PM
Project: Brushless Carbon Jato RURC Electric Off-Road 58 01-06-2011 07:46 PM
2009 Northwest Championship Tour (NCT) gatermaxx Northwest Racers 939 02-12-2010 08:28 AM
Orion to ship brushless motor KerryG Electric On-Road 40 12-09-2001 05:26 AM
