Old 12-13-2008, 10:06 AM   #1
CaptCrunch's Avatar
Trader Rating: 17 (100%+)
Default Replacing CVD pins
Howdy folks,
I'm wondering if anybody here repairs their worn CVD's rather than replacing them. I have a couple of used 1/8 scale vehicles (Jammin X1 CRT, Kyosho MP7.5) with worn CVD's. I've looked at them closely, and almost ALL of the wear is either in the universal joint connecting pins or the dogbones on the end of the CVD. The actual machined pieces themselves have very little if any wear. If the pins could be pressed out and replaced, most of the drive slop would vanish. I'm just wondering if this is something that people do, and if the pins can be purchased.
Kris
Never met an RC I couldn't crunch! If it never breaks, you're not playing hard enough.
Current Toys: 1990 RC10 Gold Pan buggy, 1991 RC10 Team Buggy, AE TC3, Diggity Designs XLR8, Tamiya TRF 415, Losi Mini Late Model, Losi Mini Slider, AE RC18MT, 2 Jammin X1X CR's, 2 Jammin X1 CRT Pro's, HPI Savage XL, Revo Platinum, Jammin X2 CR Electric Conversion, 4X2 Slash, 4X4 Slash, Losi Comp Crawler, Arrow Shark 47" Boat, Blade 400 Heli, Blade CX3
CaptCrunch is offline   Reply With Quote
Old 12-13-2008, 10:52 AM   #2
Jaz240's Avatar
Trader Rating: 52 (100%+)
I think it varies with each company. i am not sure if they are all made the same. I know my Hudy CVD's have replaceable pins, but without the Hudy tool ($100) they are really difficult to change. I would see if your manual has part numbers for the pins only. If it does that means they are replaceable, if not, you may need to buy all new CVD's Some companies would do that on purpose so you need to buy a $20 part instead of $5 worth of new pins
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 12-13-2008, 10:54 AM   #3
YES, rebuild them if they are not bent, its cheap and easy, HUDY makes a tool to take the bone pins out and the joints are easy. It will cost less than the price of one set of cvds to rebuild all of them. I just rebuilt the ones on my mugen.
Mugen, RB, Cold fusion fuel
hambydsgb is offline   Reply With Quote
Old 12-13-2008, 10:57 AM   #4
My computer is slower than his sorry
Old 12-13-2008, 10:57 AM   #5
Jaz240's Avatar
Are all the CVD pins on ever buggy replaceable?
Old 12-13-2008, 11:12 AM   #6
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
You can rebuild the dog bone end on any 1/8.. the CVD end is only rebuild-able with certain manufactures,, for example Mugen CVD's are completely rebuild-able, where Kyosho is not, because the CVD doesn't come apart where the CVD joint is.
I use this micro press tool from "innovative design"
http://www.carolinasrc.com/Webstore/...?idproduct=464
The pins need to be the correct length from centers, to F/R axles....centers are 1 mm shorter so they don't hit your break discs. The Xray pins seem to be the strongest IMO, and can be used in most 1/8 cars. Good luck!
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 12-13-2008, 11:44 AM   #7
Integra's Avatar
i use the Motion Pro Knock off pin press.....they can be had for 35$ on ebay....easy peezey to change pins....but a MUST is Liquid red loc tite to hold the pins in as they Will come out without it.
http://cgi.ebay.com/ebaymotors/Motor...motiveQ5fTools
Old 12-13-2008, 11:54 AM   #8
jpalessi's Avatar
WOW that's some set for 38 bux!
What car do u run that you havta use the red LT? I've been replacing the pins for years now with no LT, and no problems.
Joe Alessi
www.Lucky7RC.com
Old 12-13-2008, 12:07 PM   #9
omarwashington's Avatar
I had a machinest make a tool for me in which he too a small block of steel and drilled a 4mm hole through it. Then I would take a C clamp and press out the pin.
omarwashington is offline   Reply With Quote
Old 12-13-2008, 12:36 PM   #10
Integra's Avatar
ive had a couple losi and mugen pins walk when i didnt use it.....and imo the tool i posted is the most user friendly possible...you can do it IN you hands with little effort...lots of the smaller versions i see would be a Nightmare to turn that many thread on an Allen head and how would you go about holding it...you would need another pair of plyer's or something to Grasp it.
Old 12-13-2008, 01:28 PM   #11
jpalessi's Avatar
yeah I've been rebuilding the mugen cvd's for years now , and i haven't had any walk out on me. The tool I posted just requires a 10mm wrench, and it pushes them out no problem. To be honest it's a really expensive tool with a HUGH mark up, but it's paid for it's self many times over in the time I've own it. The ebay one for 38 buxs looks really nice to, and will serve other purposes I'm sure.
Joe Alessi
www.Lucky7RC.com
Old 12-13-2008, 03:45 PM   #12
Trader Rating: 47 (100%+)
+1 for the red LT. I have also had the bone pins
walk. I pressed a new pin in with some red LT and
they have stayed put.
rageworks is offline   Reply With Quote
Old 12-13-2008, 03:47 PM   #13
Trader Rating: 21 (100%+)
I use a bench vise and a 1/4" drive socket - takes a few minutes. Use the vise to press the worn pin out into the socket til its flush and then use new pin to finish. Take worn pin out of the socket, set it back up in vise and press the new pin in until centered in the bone.
I have a few UE based trucks and with the TI shafts, you don't need red loctite, for steel cvds, its a definite.
Duster_360 is offline   Reply With Quote
Old 12-13-2008, 07:30 PM   #14
Integra I have news for you thats not a MP knock off its the same one I have. Mine says motion pro on the sticker & has a blue case but it all looks the same,all the parts are in the same place in the case,spring is the same color only I paid around $100 for mine & they dont sell it no more,lucky you.
There must be some differanc though because mine is a biotch to use & is no where as easy as the bone saver.I finaly used a buddys bone saver & am getting one of my own now. Its so far supperior to the MP one I have retired mine back to the bikes only tool box & am waiting on the bone saver one to replace my pins now. No joke find one & use it & you'll do the same.
butch man is offline   Reply With Quote
Old 12-13-2008, 07:39 PM   #15
jpalessi's Avatar
+1 bone saver is very user friendly. I change out pins track side in minutes.
Joe Alessi
www.Lucky7RC.com
Hpi Pro 4 Barry White Electric On-Road 16052 08-08-2017 02:05 PM
Jammin CRT .5 = 1/12 Truggy Team Kamikaze Nitro Off-Road 2269 07-02-2017 04:32 PM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
Xray 808 09 vs Losi 8ight 2.0 chad24 Nitro Off-Road 26 04-29-2013 07:25 AM
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 01:42 PM
Fusion EX1R PRO Set up/tuning/Build thread yoshgixxer Electric Off-Road 318 08-07-2009 06:43 AM
