Ceramic Bearings Through out the Chassis?
#16
With ceramic clutch bearings what is the benifit? I hear people talking about using these in their clutch and getting 3 gallons etc. So my question is how do you know when they are about to go? I use bearings that are a buck a piece. I change them before the mains and always start a main with new bearings, so I know I should be good there. But if I have a set of ceramics that I am trying to get "mileage" out of how do you know when they are about to go? I know if they are loose, rough and sloppy they are coming out, but is this the only way to tell? I sure don't want to find out in the middle of a main that ceramic bearings that have two gallons and are supposed to go three are going to take an early dump on me.
Thanks in advance
Thanks in advance
#17
That is a good question. I guess it is a risk you take. I just try to watch my clutch bell for excessive play and and like you said scratchy or loose bearings. I sometimes take chances on the cheap bearings if I am runnning low on them but that is at club races.
#18
Yup, that's about right. $69.00 PER BEARING. For the average 1/8 buggy there are about 18 bearings, so that's just a hair over $1200.00 for a full set (as much as the cost of 2 whole, brand new buggies.)
You could literally replace ALL the steel bearings in your car every single weekend with a new set for a whole year and a half and still cost less than one set of ceramics whose durability is still in question.
#19
BOCA BEARING
Full ceramic 8x14x4mm $89.95 each.
No thanks
No thanks
#20
That is why I use the Ultra Yellow Seal bearings. The yellow seals are what Jay would recomend in the first place. You will be impressed at the performance and durability of the bearings.
#22
i boca ceramics in my motor and i love them.. i use the $1 clutch bell bearings from them also
#23
I have been running mine for a little wile now and am happy with them. Ran the ceramic clutch bell bearings that came with the kit and I will be running the $.99 bearings from now on in the clutch.
#24
http://www.bocabearings.com/
Hope you enjoy! I have 5 races on my yellow seals and not one failure or even a gritty bearing.......most of all.....no maintenance!
#25
wow those yellows are $200 anywhere to get them cheaper?
