Old 12-06-2008, 09:33 PM   #1
Gixxer2k4's Avatar
Send a message via AIM to Gixxer2k4
Default Glueing Tires
Well tried to glue tires an barely got my hands of the tire before the glue dried lol. Had a small moment of panick for a second. Gonna have to dig for a thread of a vid of how to do it to prevent glueing myself to stuff.
It was my first attempt trying
Super Glue-1
Me-0
Gixxer2k4 is offline   Reply With Quote
Old 12-06-2008, 09:55 PM   #2
Tree's Avatar
Send a message via ICQ to Tree
http://www.youtube.com/watch?v=_vmWf...C98050&index=0
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 12-07-2008, 01:44 AM   #3
Bigedmond's Avatar
Trader Rating: 18 (100%+)
That video misses a very important step. After using the sanding wheel on the rim and tires, use rubbing alcohol to clean the tire and rim.
As for glueing, i use a small paper cur with more of the wall cut off. I will put some glue in the cup, and use a flat edged tooth pick to apply glue to the inside bead. Then when i am done with the bead, i use the fat end of the flat toothpick and smooth any glue that squeezes out and apply a smooth amount that covers a little rubber and rim.
Bigedmond is offline   Reply With Quote
Old 12-07-2008, 02:05 AM   #4
sirKandal's Avatar
whats the best glue to use on wheels?
KYOSHO MP9TKI2WCE / OS Speed/ Radiopost
TEAM TERRIBLES Minicar.no
sirKandal is offline   Reply With Quote
Old 12-07-2008, 02:53 AM   #5
Gixxer2k4's Avatar
thanks for the tip guys..
Old 12-07-2008, 06:26 AM   #6
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
FUSION!!!
jamminnay is offline   Reply With Quote
Old 12-07-2008, 07:19 AM   #7
Trader Rating: 8 (90%+)
I hate gluing tires I don't have the dexterity to do it well. I buy pre glued LOL!! Though they definately don't stayed glued as long as when I do it myself.
franklucas is offline   Reply With Quote
Old 12-07-2008, 07:58 AM   #8
Trader Rating: 61 (100%+)
aka glue or losi glue has worked best for me
i didnt see in here if anyone mentioned tire bands ...they are the single best thing you can use to make sure your tires are right ...get em prepped get the tire bands around them and then peel back section around the bead and lay small small amounts of glue in there ....do one side let em dry for about a few hours then flip em and hit the other side ....on truggy tires my buddy had showed me you could also use electrical tape in place of tire bands ..and it was golden worked like a champ
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 12-07-2008, 10:28 AM   #9
slidejob26's Avatar
I have the best luck with Fusion or losi
Scott
PERFORMANCE RC, Burlington WA 360-755-7084/360-755-9464
slidejob26 is offline   Reply With Quote
Old 12-07-2008, 10:34 AM   #10
Bigedmond's Avatar
For glue, i dont care, what brand it is, i just make sure its less then a month old, because glue does go bad.
For bands i use panther bands. I find using the 8th buggy bands on truggy tires works best, and panther 10th bands work best on 8th buggy.
1 key that i learned from pros. Also glue the outside first when at the track. That way it has the longest time to set. Most tires blowout on the outside, so giving them a little extra time to set is best.
Old 12-07-2008, 10:53 AM   #11
yeh bands are the best ...if im not in a hurry i will usually let the sides dry over night ...but i spared saying it as most people wont wait that long ...it truley does make a huge difference if you let em dry over night ...
LATER COOKIE
TEAM PROLINE-RACING
Old 12-07-2008, 04:39 PM   #12
Integra's Avatar
AKA
tire bands are a MUST.....i actually use my MT bands for everything...buggy and truggy....as most of the new buggy wheels are a taller diameter and dont require the foam Crushing force of the buggy bands....and glue your tires DAYS in advance...why bother with glueing on race day ?
Old 12-07-2008, 04:49 PM   #13
jamminnay's Avatar
sometimes you have to glue tires on race day.. it happens.. this year i bought mostly pre mounts though. only glued when i got in a pinch.
Old 12-07-2008, 05:29 PM   #14
Use the losi's plastic needle that goes in the bottle I squish the end nearly closed with the thin glue. Super control. I open the bead and work my way all the way around withe the losi bands in place . I know some guys that open the inside of the tire up and add an inside gluing to the outer bead. They do the outer bead first of coarse.
153stars is offline   Reply With Quote
Old 12-07-2008, 06:19 PM   #15
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
I use panther bands and losi blue(medium) glue. with the bands on(directly over the bead) I use the little tube that comes with the glue and go around the tire peeling the bead back slightly. I then use the tube and basically draw a thin line of glue around the inside of the bead about 1/4 of an inch in on the bead of the tire. leave the band on for an hour or so and start the same process on the back side. Don't use alot of glue or it will just mess things up. using too much glue lengthens the drying time and actually weakens the glue joint plus it makes a big mess. since I started using this method I have not had one single tire failure plus my tires look alot neater.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Hpi Pro 4 Barry White Electric On-Road 16052 08-08-2017 02:05 PM
Turtle Trax, Sat. Race 7/11 tinasam Georgia Racing 164 07-13-2009 07:27 AM
TAKE OFF CS-22's Pre-glued Problems EDWARD2003 Electric On-Road 16 12-12-2007 12:42 AM
Glueing Tires RoadRat Electric On-Road 9 07-23-2003 10:38 PM
