Old 12-04-2008, 07:59 PM   #1
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Default tapered angle on turbo glow plugs????
Do different companies use different tapered angles on their turbo glow plugs?
rallyebmx is offline   Reply With Quote
Old 12-04-2008, 08:07 PM   #2
22Racer's Avatar
Trader Rating: 67 (100%+)
I measure the angle on a comparator quite a while ago and the angles were the same on the ones I tested. What I found was where the thread starts, on some they had a flat before the thread, on others the thread started right where the angle meets the thread.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 12-04-2008, 08:59 PM   #3
Integra's Avatar
yes some plugs have a differnt taper to them.....which plugs are you compaing or what motor are you trying to match a plug to ?
PS Rex...see you at the Ranch tomorrow.
Old 12-04-2008, 09:12 PM   #4
22Racer's Avatar
Actually we wont be making it up there until Jan. , Kendall has finals next week!
Rex
Old 12-04-2008, 09:23 PM   #5
rallyebmx's Avatar
Picco plugs on an RB
Old 12-05-2008, 04:24 AM   #6
Mark_Australia's Avatar
Man I can't see it would matter.
As long as the surfaces are concentric (ie- the centre of the threaded section is the same as the centre of the bevelled section) ..... it will work. What would happen if it were not concentric is that when you screw it in it seals on one side and not the other...
The bevelled section is what, about 1/8" long? You'd only need about 10-20% of that to form a seal. If it did not seat all of the bevelled section against all of the countersunk section in the head you'd see obvious marking on the plug after a few runs .... like the bronze discoloration ont he bottom of the plug would also extend part way up the bevelled section...... and you would not buy that plug again
Mark_Australia is offline   Reply With Quote
"the tuning bible" houston Onroad Nitro Engine Zone 311 04-24-2017 11:18 PM
Atria Car Park Speedway tIANcI Malaysian R/C Racers 26519 12-07-2013 06:04 PM
Yay Dvx400Rider Nitro Off-Road 7 02-27-2009 08:25 PM
Please Help Muah! Speedjunkyz Nitro On-Road 36 09-05-2008 07:13 AM
