Wheel Balancing
Wheel Balancing
I wanted to start balancing my buggy and truggy whells just a couple of questions?
1. what is the best balancer?
2. can u use just regular modeling clay to balance if not what is the best?
thanks
thanks
I use the Ultimate Racing wheel balancer and use regular modeling clay...haven't tried the clays that are labeled specifically for rc wheel balancing so I can't compare.
http://cgi.ebay.com/Ultimate-Racing-...20105006r13208
Jammin has also released a wheel balancer that looks very similar to the Ultimate one
yes you can use modeling clay.. that is what i use anyway
I am by no means being critical of wheel balancing... I am new to the off-road buggy and truggy scene. I was previously racing touring cars.
Does balancing the wheels make a noticeable difference?
Do you notice a specific characteristic associated with un-balanced wheels?
Thanks.
Thanks.
Balancer I use
http://www.carolinasrc.com/Webstore/...idProduct=1029
I dont know if its the best but it is about the most free spinning precise you can get & is what most the people I know use . I got mine for $15 on sale at hobby people many years ago & havent been able to kill it yet. Those new style single sided ones do look easier to use just a lot more expensive & not sure how presice/free spinning the bearings they use are.I may try one if I ever have that much money to spend though. I use a old hub & wheel nut from my jammin stash to mount the whee. on the balance shaft.
For puddy I use a product from the home depot electrical section called Duct seal.Its ment for sealing around where elec conduit goes through a brick wall.This stuff sticks like crazy & is heavy so a little bit will do what 3X the modle clay will cant do.comes in a brick like 6"x2"x1". Thats a lifetimes worth & sells for like $2.
Wheel balancing makes a huge difference in car handling especially for truggy. As for characteristics,Have you seen a car on the starter box look like its gonna come off when reving the eng to warm up or a truggy look like its gonna shake its self apart on a straigh or look like its having convultions in the air? Thats what balancing stops.I even balance buggy wheels now & going through a sweeper turn you can not onl feel a difference but you can see it from 40' away on the stand. Just pay attention next time at the track & you'll be able to spot the wheels that are balanced from the ones that are not. Unless their using AKA combose as those are so balanced you dont need to do them. I havent used AKA truggy tires yet but my buggy ones have about a 1/2 gallon on them & still dont shake on the starter box. Balancing gives a HUGE ADVANTAGE for the price & effort.
AKA's Still require balancing.......they are alot truer then most tires...but by no means are 100% purfect...for zero off wheels you can use putty...but 1/2 off wheels you HAVE to use the tape....if you dont your not helping the balancing situation what so ever.
where's the center line of the tire on a 1/2 off wheel....right in the center.....IE you go stuffing clay off center isnt helping the issue......tape you can apply in layer's if needed and also can be placed where the weight is needed...clay just wont cut it......zero off wheels...Sure...thats where the clay comes in handy.....i still use the tape....but thats a personal prefference....and i go as far as to balance the rims on a magnetic balancer prior to mouting the tires aswell....Im anal to say the least.
Balancer I use
