Old 12-04-2008, 06:15 AM   #1
Default Caster big bore shocks
Hi guys, bought these for my xt8, absoultely brilliant but found they abit cheap really.
the front end shock kept leaking and only just noticed the e ring / metal ring keeps popping out .
u guys have any suggestion??
cheers
muaythai is offline   Reply With Quote
Old 12-04-2008, 06:19 AM   #2
skeller's Avatar
Send a message via AIM to skeller Send a message via MSN to skeller Send a message via Yahoo to skeller
cheers
Hmmm...I've got 2 complete sets of them with 2-3 gallons on each set...never had and issue with them.
Are you sure that the ring is in the groove properly?
You may also try a different clip...I got into the habit of using Mugen clips on all my shocks several years ago. They work perfectly in the Caster shocks...as they do in many others as well.
SK
skeller is offline   Reply With Quote
Old 12-04-2008, 06:34 AM   #3
skeller's Avatar
Here's what I've bought in the past...they work on several different brands of shocks.
http://www.tiltedrc.com/product_info...2151be5ea58a35
Old 12-04-2008, 09:13 AM   #4
vnmsgt's Avatar
I might try a different clip too. I have 3 sets that have been perfect for me. Also make sure your shock shaft is not bent if you ran them already because if it is bent close to the shock body than it could hit the clip and pop it out or wear a groove in the shock shaft and allow fluid to leak through that groove. Hope that helps any.
Check out www.holeshothobbies.com
Now offering support for: Agama, Caster, Serpent, Mugen, HotBodies,VP PRO, Answer-RC and much more.
vnmsgt is offline   Reply With Quote
Old 12-04-2008, 12:58 PM   #5
razzor's Avatar
also check the flat part of the clip is not touching the shock shaft.
If it is it will score the shaft and start leaking .
I ruined 2 sets of shafts like this.
I always bend my clips a bit to the side so they dont touch or are close to the shaft.
some AE shock slime or rubber grease on teh orings also helps prevent leaks .
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Kyosho SP2 WC Edition Shocker Nitro Off-Road 300 08-30-2011 08:17 AM
Caster Racing ZX-1.5R 1/8 buggy Briguy R/C Items: For Sale/Trade 6 03-27-2009 06:08 PM
Your opinions on the Caster Racing Fusion hakmazter Electric Off-Road 35 09-30-2008 08:10 PM
Caster Racing 16mm Big Bore Shocks vnmsgt Nitro Off-Road 16 09-23-2008 09:16 AM
Choosing a Big Bore Shock Cain Nitro Off-Road 15 03-10-2008 01:56 PM
GS CL-1 x2 *fioroni hopped up,RB S7lll,Collari B7,Starter Box etc. GSCL-1 R/C Items: For Sale/Trade 10 10-22-2007 06:56 AM
