Old 12-04-2008, 05:32 AM   #16
tex1's Avatar
Send a message via Yahoo to tex1
Post
Now you need to ensure your have the center drive shaft stuff sorted correctly. Then you need to read - read.
It will be bullet proof before you go out.
Smoking good cars.
TEX
tex1 is offline   Reply With Quote
Old 12-04-2008, 06:40 AM   #17
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default Read Read Read.....
Ha I'm only on page 8 of this thread.
Any hints of what I need to do to bullet proof the buggy?
Many Thanks....
RED-LINE M03 is offline   Reply With Quote
Old 12-04-2008, 09:27 PM   #18
Many Thanks....
Just make sure the screws are tight, thats about it. The chassis is strong right from the box.
Ive done everything Hank did but die
NCWC is offline   Reply With Quote
Old 12-04-2008, 09:37 PM   #19
Jaz240's Avatar
Trader Rating: 52 (100%+)
Many Thanks....
There's not much to know. If the buggy is used you should replace all the bearings. Keep an eye on them, and clean, or replace them every 2-3 gallons, take apart the front and rear bulkhead and make sure whoever built it, did not tighten the inner bearings too much. this will cause overheating and blown bearings, and may strip out the diff gears. you don't need any option parts, and the stock set-up is close to perfect. You should also rebuild the shocks since you dont now how well he maintained them. Good luck have fun, talk to you on the XRAY forum
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 12-04-2008, 09:45 PM   #20
Nice! That used Xray will last as long as any new buggy from any other manufacturer. LOL! Have fun!
Inside_Line is offline   Reply With Quote
Old 12-05-2008, 08:00 PM   #21
Thanks for the heads up guys. I can't wait to hit the dirt. Looks like no more 12th scale for me. This buggy looks like so much fun.
