Old 12-02-2008, 07:10 PM   #16
I use small dykes on the last thread beforethe shaft goes smooth works better than any thing I have purchased in the past. My shock ends when built to the correct length have a little thread showing so lucky me. The Tamiya pliers were the biggest wast & the ones pictured above worked mostly good for a while then went in the junk drawer after a bit. Believe it or not I used that little bronze disk for many years with only slight modification & loved the end result just not the pain balance job with the pliers.BTW to correctly remove the disc you flip/pivot it up using the rod end as a fulcrum & it spreads it apart & pre sets it for the next shaft.
WOW I just went back & looked at the price of the disc. Holy crap they were like $1.50 back in the 1/10 scale days & every shop sold them so no shipping fee. Man no wonder you sent it back.
butch man is offline   Reply With Quote
Old 12-02-2008, 10:00 PM   #17
Joe_Racer's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Duster_360 View Post
I've been using wire cutters and carefully grabbing the shaft right at the shoulder above where threads quit - yes, leaves a mark, no, its never caused a prob since seals never move across that part of the shaft. Built plenty that way.
If I have to pull a shock apart I'll use a fine file and remove that mark so it doesn't harm seals when I put it back together. Shafts are pretty hard and you don't leave that much of a mark anyway.
+2
Jack G.
Mugen MBX-7 Novarossi Plus 4, Mugen MBX-6TR Novarossi P5
RC10 GT2 OS TG, RC10 B4.2 17.5, SC10 FT 13.5, RC10 T4.1 13.5
Joe_Racer is offline   Reply With Quote
Old 12-02-2008, 10:38 PM   #18
Jaz240's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Joe_Racer View Post
+2
+3. That's how the instructions in my first Kit showed me to do it, and I've been using that method ever since, never had any problems
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 12-02-2008, 10:53 PM   #19
rcboxer's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to rcboxer
lol, I just use regular pliers, never have left a scratch yet.
rcboxer is offline   Reply With Quote
Old 12-03-2008, 09:25 AM   #20
bjr48's Avatar
Didn't come with instructions so I didn't know that resetting the disc was to be expected. But in my case no matter how &*^% hard I compressed the disk it would not contact the shaft enough to hold it with 3mm shock shafts so I sent the thing back. It came close to touching the shaft but didn't even begin to grab. ?
I'll probably give the pliers a try. If they don't work for me or don't last long I'll go the home made route and make a better disc tool on my own or make my own brass or nylon liners to expoxy to a set of pliers or something that I can replace over and over pretty much for free. I definately want some kind of soft clamping device becuase I think that is what will work best.
bjr48 is offline   Reply With Quote
Xray T1 David Galdo Electric On-Road 12705 07-04-2016 01:07 AM
Atria Car Park Speedway tIANcI Malaysian R/C Racers 26519 12-07-2013 06:04 PM
Associated Factory Team TC5, Brushless, LiPo, Li-ion Nanophosphate, Tips and Tricks John Stranahan Electric On-Road 839 11-01-2011 03:31 PM
threading eyelets on shock shafts?? xv-townboy Electric On-Road 10 07-01-2009 04:49 PM
Rustler VXL suspension issue Osiris1012 Rookie Zone 6 04-09-2009 08:48 PM
