Head Clearance
Head Clearance
Could I please have detailed directions on measuring head clearance? thanks I do have a digital calipers
Frank,
pull the back plate but leave the head bolted in place. turn the crank to TDC (top dead center) then pull the head and shims. (if you turn the crank with the head removed there is a good chance you will cause the sleeve to slide in the block and this will affect your first measurement.)
1. Measure from the top of the sleeve to the piston face with the probe on the butt end of the caliper. (write the number down)
2. measure the length of the portion of the head that inserts into the sleeve.(again w/the probe on the butt end of the caliper)
3. measue the thickness of the shim(s)
take your answer from #1 - #2 + #3 = your head clearance (aka. deck height).
hope this helps
chunk
hope this helps
chunk
way easier method.
remove glowplug
get a 4" long piecethin piece of solder
bend the solder into an "L" shape 1/4" from the bottom
stick the solder into the head button
slowly spin the crank one revolution
pull the solder out and use your calipers to measure the thickness of the flattend solder.
done..........
remove glowplug
done..........
Frank,
hope this helps
chunk
hope this helps
chunk
i get a .30 reading woth no shims? does this seem acccurate? so with the .30 shims that came on the engine that makes a total of .60 head clearance?
mm
duh sorry new at this thousands would be .024?
axe rossi x1 comp. 30% fuel
