Old 12-28-2008, 10:47 PM   #46
8&stuff's Avatar
Trader Rating: 55 (100%+)
long tracks 4 sure..
Mark Buecker
8&stuff is offline   Reply With Quote
Old 07-06-2009, 07:38 AM   #47
shipwama's Avatar
i am having some major problems with my s5 l2g, the top end is great, when it gets up there, im having low end issues
i have the s5l2g running 30% fuel and i have the 053 mr pipe
i have mc8 plug, i think and i have a bogging issue on the low end, i am a relative newbie here, and have had experienced tuners try and tune in my engine, the low end stays shitty, i dont know what to do
when i punch the throttle it bogs for like 3 second then takes off, we have leaned it and richened it, and still the same thing
shipwama is offline   Reply With Quote
Old 07-06-2009, 08:16 AM   #48
JUD
JUD's Avatar
I would put the needles at factory. 3 1/2 hsn 5 lsn. Lean out the hsn about a quarter turn. Then lean out the the lsn. Lean it until it sounds good. If that don't work you may have a leak.
JUD
Mugen Seiki - AB Mods - AIRTRONICS - Ninja - CR Graphics - Spektrum
JUD is offline   Reply With Quote
Old 07-06-2009, 08:43 AM   #49
aaron joy's Avatar
Trader Rating: 16 (94%+)
There could be many reasons why your low end is bogging. Did you shim the engine for 30%? What clutch are you using, a clutch that is grabbing too soon could load the low end. You may have a leak from the front bearing or around the carb area. Try a different plug like a RB#6 or a Mc59. Post some answers to the questions I asked so we can better help you.
aaron joy is offline   Reply With Quote
Old 07-06-2009, 01:07 PM   #50
shipwama's Avatar
ok, i have the head shimmed correctly, we have .4 under it, the clucth im using is a jammin 3 shoe, stock in my buggy, with 1.1 or gold springs, that have under 2 gallons on them,
Old 07-12-2009, 06:14 PM   #51
shipwama's Avatar
Hello again, would the S5 l2g be better off with a mid range pipe such as the dynamite 053mr or a low end pipe, like maybe the JP1? thanks im running 30%
Old 07-12-2009, 06:50 PM   #52
Trader Rating: 2 (75%+)
try a rb2045 its a real good pipe
cjhorne is offline   Reply With Quote
Old 07-12-2009, 07:16 PM   #53
shipwama's Avatar
well i dont have one of them i have the choice between jp1 and dynamite 053mr for this weekend, Motor is at factory settings right now
Old 07-12-2009, 08:46 PM   #54
8&stuff's Avatar
best pipe i found was 086 with short double bend manifold. sometimes i got a low end bog too. was always solved with keeping the fuel lines level. even if i had to keep zip ties on them to hold in place. i liked the 2045 but a little less runtime. since your happy with your top end i would use an 086 with stock headeryou will be pleased. just try keeping fuel lines all as close to equal height
Mark Buecker
Old 07-12-2009, 08:56 PM   #55
shipwama's Avatar
i had the clutch shoes in backwards, which was i believe causing my bog problem, which was also causing the shoes to rub against the clutch bell on the sides im going to try to continue with the 053 mr
Old 07-12-2009, 09:04 PM   #56
8&stuff's Avatar
sound like your good!
Mark Buecker
Old 07-12-2009, 09:15 PM   #57
shipwama's Avatar
hopefully that will fix it
RB Concept Engine Thread.. r1harper Offroad Nitro Engine Forum 3632 06-14-2017 12:29 AM
RB S3 or S5 Chris__RC Nitro Off-Road 8 01-31-2009 03:20 PM
need help with my rbs5 L2g!!! Mark Erce Nitro Off-Road 13 01-08-2009 04:03 AM
RB Concepts S7 question...... TXRC8racer Nitro Off-Road 23 11-26-2008 05:25 PM
RB S5 L2G mixedguy Nitro Off-Road 12 09-22-2008 04:02 AM
RB S3 L2G ? vladconnery Nitro Off-Road 7 07-06-2008 05:42 PM
