8T 2.0
#1156
I only have one weekend on my truck so I can only speak from that experience. But I had Avids on my truck, traction was ridiculously high, jumps were HUGE and there were lots of high speed sweeapers wich really side loads the rear bearings. I just checked my bearings and they all still feel really good
#1159
I can say that I have had the 8T2.0 to the track 3 times and came home with a blown rear outter wheel bearing twice. I am getting the bigger bearings in order to try to avoid failures in the future. I know exactly how I am blowing them, and would like to try to fix it before any other options.
#1161
do you know if the crosshairs and double dee's come with molded inserts in truggy? thinking of trying out there new truggy tires but hate open cell foam inserts!
#1164
the cross hairs have molded foams, not sure if they are open or closed cell, the double dees are not molded but they balance out just as good as the others, i practiced this weekend and ran 2 qualifiers and a 30 minute main on a abrasive blue groove track and still have tread left, i ran the soft blue compound also, didnt have to balance them at all they are perfectly balanced
#1165
what i am doing is modding the outer bearing race to fit a 8x16x5 which replaces the stock bearing that is an 8x14x4 not much to do for the inners but the longer the outers last the longer the inners last. here is the pic of the hub and spindle with the bigger bearings.
#1166
I have got about a gallon on the truck now and I am on the third set of outer rear bearings. I have a set of modded hubs on the way from J-DUB. As soon as I can put some time on them, I will post a review.
#1168
I am running Panther 38 switches with OFNA molded foams on PL LPR rims that have been balanced.
#1169
i also balance my wheels and am running panther clay switches with boa foams an losi wheel and clay raptors with panther grey foams on losi wheels and keep rebalancing do to losi wheels breaking when you look at them wrong
#1170
rc-batt how are your bearings and when are you coming by the shop pimpin
