8T 2.0
hey guys for everybodies reference can we get a list of the Hex Wrench sizes needed for this truck!...thanks in advance guys!
my losi 8ight t needs some help
losi racer:
thank you for your reply. I been online for over 10 years and im only a member a a few forums. Its good to know i picked the right ones to get usefull information. you guys are great. With the replys I got so far I think I can fix my truck starting with the hinge pin check. if thats straight i will move on to other suggestions. I cant start working on it yet. I have a race saturday and i am primarily running my ve8 wich requires a new mamba max pro case and some service. thanks to all that posted to help me and keep them comming. others may have the same problem and it may not require the same fix as mine.
lol, and i think that .5 is for the ball link on the slide of the carb. i think the only wrench on the truck. very uncommon for small bolts. if its small, its usually 1/16th.
The throttle ball on most engines uses a metric 1.5mm wrench. The SAE .050" wrench is used in all the set screws on adjusting collars on the throttle linkage and on the sway bar set screws. The 1/16 wrench is used for the shock piston screws, on the clutch pins, on set screws in the drive shafts and in the steering spindles. Pretty much the rest of the truck is 5/64 and 3/32. I might have missed some stuff, but you do need all 4 wrenches as well as 3/16", 1/4" and 11/32" nut drivers.
the 5/63 is my fav
and the collars for the linkage
losi racer:
2mm-clutch bell screw.
Quick inquiree
Hey guys,
Just registered here. Been running the HPI Savage for a while before I sold it prior to my deployment to Iraq, I really regreted selling it. Anyways, Im home on leave and my brother gave me his Losi 8ight 2.0 with Futaba 4PK FASST radio, the question is, what spare parts should I buy before heading back out to Iraq Christmas day to take with me, and how the heck am I supposed to ship nitro fuel out there. Thanks in advance for your replies.
SSG Arinas
A CO, DSTB, 4th ID,
COB Speicher, IRAQ
APO AE 09393.
SSG Arinas
A CO, DSTB, 4th ID,
COB Speicher, IRAQ
APO AE 09393.
Hey guys,
SSG Arinas
A CO, DSTB, 4th ID,
COB Speicher, IRAQ
APO AE 09393.
SSG Arinas
A CO, DSTB, 4th ID,
COB Speicher, IRAQ
APO AE 09393.
Hinge Pins
CV Drive Shafts
Front / center Drive Shafts
Front / Rear Diff Case
Shock Boots / Bladders
Shock Oils / Diff Oils
Bearings
Clutch Shoes & Springs
Glow Plugs
I know they have hobby stores KWT is from their maybe PM him about support and gas many you can buy from their.
Here's a link stroll down look for KWT (member) I think hes familiar with the area
http://www.rctech.net/forum/offroad-...h-e-s-190.html
