How are you guys getting the slop out of the rear wheels ? I've shimmed the backside with diff shims. They seem good, then after one run there loose again. I have the modded J-dub plastic rear hub carriers.
Is there a fix for this, or is this just what all truggy's do since the tires are so big ? Should I be shimming them differently ?
Trace the Slop back to where its coming from....are you Positive its not a ball end on the tower or knuckle....are you sure its not the knuckle itself slopped out on the 3.5mm hinge pin ? the alum balls have a tendency to slop out if you get your truck real dirty and don't clean it properly....If it's the Axle itself....you want a hair of slop...like .1-.2mm and no more....just enough to feel a "tick" of play in the axle to the wheel hex.....MAKE sure to check it with the Grub Screw Tight as that Will take up some of the slop.
Blue Groove Apparel - Hitec - Losi - W.E.D. Paint - Byrons Fuel - O.S. Engines - Tekin - Futaba - Clockwork Engines Team Driver - Matrix Concepts.
I think a lot of the slop is coming from the wheel hexes, so I swapped mine with a set of xray 808 hexes that I got off ebay for $15-huge improvement, no shimming and ir still has slop just not quite as much
Another local racer put the hexes off hos 1.0 buggy on his 2.0 truck and also liked the rrsults-it doesn't make the truck twitchy like shimming can if it gets too tight
Losi 8T 2.0 with a powerhouse modded extech 24 ballooning the tires!!!!!
New house toy 1/16 vxl revo on 4s with one broke front axle shaft and many more to come
I put a little piece of electrical tape on the axle and it took out 80% of my slop in the rear wheels. The axles kind of "float" in the bearings which is what is causing the slop.
Tell me something guys? I just got a used 1.0 truggy, my first truggy ever. I was on eBay and found 3 sets of truggy half offset rims new for 51.56 shipped , will they fit the truggy, or not. And another question is does anyone on here have a good chassis for the 1.0 truggy I can buy from them, or tell me where to find a chassis like a flex tune? Thanks guys
The half off set rims will work just fine, it comes with half off sets out of the box. For a chassis you can try ebay. They are not cheap.
If you are going to drop that kinda cash on a new chassis then get a 2.0 chassis from bce and a new rear center drive shaft. You will be verry happy.
- BCE 8ight T 2.0 - OS Speed II - DX3R - Hitec 7950 - 7940
- BCE 8ight 2.0 - OS Speed II - DX3R - Hitec 7950 - 7940
- powerhousercperformance.com <<Engine Mod Magic<<
- coldfusion fuel - www.coldfusionrcproducts.com -
- carolinasrc.com -
DONT waste your $$ on a dragon racing chassis either...there JUnk and Wont last more then a weekend or 2.
Losiracer77
I have a Losi 8T 1.0 Chassis that is in pretty good condition that I was selling for pretty cheap if you are interested.
so does anyone have a clue if they or if some one did come out with mud gaurds for the 8t 2.0 ?
I use the mugen ones they are curved and look very cool. I had to drill a new hole but ohh well, They work very well. Most guys I know cut down the 1.0 guards.
- carolinasrc.com -
currently I know no manufactures I even called message and talked too manufactures about making none have interest I bought the parma lexan and went too town.
Losi T2.0 Os Speed World II 2060 Pipe Header
Center Diff Hitec 7955 Futaba BLS
Lighten Outdrives King Headz
I have a Brand new never run chassis for the 1.0 I will sell cheap.also have one that has about 3 runs on it If interested just PM me.Thanks,Rick
I used some thin sheets of CF for mine but originally made them from the Parma Thick lexan.....you can also make them cover a lot more then what the 1.0's did.
