Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 08-14-2009, 04:57 AM   #4141
mattwoodcraft's Avatar
the rear hubs will fit but you will need drill the holes out for the pivot pins if you use the inner hole it will be same as your 2.0 hubs
RYPER HOBBIES ~ PURPLE RUSH FUEL ~AKA TYRES
GO TECH MG66 ~ BCE CHASSI
X-ray 808 09 spec
mattwoodcraft is offline   Reply With Quote
Old 08-15-2009, 07:12 AM   #4142
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
ok i went thru 3 throttle servos, i follow the instructions , check my end points,any new advice?
Mugen MTX4R \ Ninja .12==== For Sale
Mugen MRX4R \ Ninja .21==== For Sale
Losi 8T 2.0\ Ninja .21
Team Terribles
bobbyblaze is offline   Reply With Quote
Old 08-15-2009, 07:44 AM   #4143
Frank L's Avatar
Trader Rating: 15 (100%+)
I know th feeling I went through 6 since march in his 2.0. Check the side mud guard. I bet the servo is touching it. Mine was. I had to grind away the top lip so it was nowhere close the sevo. The only other thing is usethe rubber gourments when mounting the servo. I did these 2 things and now no more servo issues. I have been using the same throttle servo now for 3 gallons and counting.
- BCE 8ight T 2.0 - OS Speed II - DX3R - Hitec 7950 - 7940
- BCE 8ight 2.0 - OS Speed II - DX3R - Hitec 7950 - 7940
- powerhousercperformance.com <<Engine Mod Magic<<
- coldfusion fuel - www.coldfusionrcproducts.com -
- carolinasrc.com -
Old 08-15-2009, 08:26 AM   #4144
Muggydude's Avatar
Is the outer air filter on the 8t supposed to be oiled or dry? The losi starter box i bought was from ebay, and the day after i bought it the dude became a no longer registered user. I hate having to wait for paypal to reimburse me, I'm going to get the ofna truggy box once I do. Can anyone show me a vid or picture of the throttle servo or horn properly set on the 8-t 2.0? I'm having a h@ll of a time setting it.
TRX 1/16 E-Revo VXL all supped up
8-t 2.0 with OS .21 VSpec with speed rod, JR 9100 servos, RE11 pipe, dx3.0
All RPM Slash with MM VXL combo and sMC 28c 5000mah 2s lipo, Hitec servo
E-Flite blade MSR
Always spend more time working on your car than driving it
Muggydude is offline   Reply With Quote
Old 08-15-2009, 08:48 AM   #4145
aznitronut's Avatar
I raised my throttle servo 2mm, with servo spacers that come with the Kyosho truggy, so that the linkage is level and not on an angle, so far, no probs.
aznitronut is offline   Reply With Quote
Old 08-15-2009, 12:17 PM   #4146
Hey everyone. I recently had a center diff go bad on me while I was in a main and my motor got really hot. I fixed the diff and i put my car on the track and it slips to the max..
clutch pads??
also, I am now running a FRONT/CENTER smart-diff. What is a good WT oil to use in the REAR.
What are the handling characteristics of HEAVIER/LIGHTER weight in the REAR.
TEAM TERRIBLES
Read the directions, and directly you'll be directed in the right direction
terzianator is offline   Reply With Quote
Old 08-15-2009, 12:21 PM   #4147
losi_racer's Avatar
ive only gone thru one servo but once you told me about the touching the side guard thing i keep checking it. the servo that went out was my fault, had epa set to high
Losi 8ight-T 2.0/ Nova +4/ Ofna 053/
Losi 8ight-B 2.0/ Nova +4/ 9853
One Hobbies/ The Nitro Pit/SRS/ BCG Industries/ Team Terribles
losi_racer is offline   Reply With Quote
Old 08-15-2009, 01:08 PM   #4148
The outer filter comes oiled in the ones supplied by losi, but as a general rule, most run with the outer dry. An oiled outer will mean dust gets stuck to it, whereas in theory it should fall off a dry one. I use what is called an SMD box here in the U.K. but it's the same box as the ofna, and it's a good box mate.
As for setting the throttle servo, then there is a guide on the Losi site mate.
SC8 MRT GRP .21
Concept Racing Team Driver
plod is offline   Reply With Quote
Old 08-15-2009, 02:13 PM   #4149
air8's Avatar
clutch pads??
Heavier rear oil will not rotate as well in the corner. But it will accelerate better coming out of the turns. However too heavy might make the rear too loose depending on track conditions.
Lighter oil will rotate more around the corners. It will accelerate smoother through bumpy sections. You might lose a little bit of forward acceleration from the diffing action.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
air8 is offline   Reply With Quote
Old 08-15-2009, 02:28 PM   #4150
Meaning, with heavier oil, off-throttle, the car will "180" through tight corners in comparison to lighter oil.
I just put 5000wt in the rear with the new additions to my "smart-diffs" (front and center). Is that too heavy?
Thanks for the explanation!
TEAM TERRIBLES
Old 08-15-2009, 02:32 PM   #4151
air8's Avatar
5000 is not too heavy. It might be perfect for you. It's hard to tell over the net, ya know? Best thing to do is try it out and adjust from there for your liking. If you still have your manual there is good brief descriptions in there towards the back.
In the tight 180* corners the lighter oil will be more planted and go around them quicker. However if you drive on throttle the heavier oil might suit you better.
--"U Ain't Fast!!"
Old 08-15-2009, 02:40 PM   #4152
shanty140's Avatar
Hey,
I was wondering how much most of you pull the filter out inside the tank. I hope you know what I mean. Like how long is the fuel tubing connect to the filter inside the tank.
TEAM TERRIBLES
Mugen MBX6T - Losi 454, RE11, O`Donnell 30%, DX3R, Hitec Servos
Losi 8ight-T E 2.0 - Mamba Monster 2200kv, 5S 30C 5000mah, DX3R, JR Servos
Losi 8ight 2.0 - Winter Overhaul Coming
shanty140 is offline   Reply With Quote
Old 08-15-2009, 02:45 PM   #4153
Sweeeet. You're the man. Thank you for the explanations. I'm gonna replace my clutch shoes and give it a try.
TEAM TERRIBLES
Old 08-15-2009, 02:56 PM   #4154
air8's Avatar
Originally Posted by shanty140 View Post
Hey,
Just pull it out far enough that the clunk inside does not hang up on the rear wall of the tank. If you look inside towards the rear, there are two walls extended out from the left and right. I keep the clunk behind those two walls BUT off of the back wall. The purpose is for the clunk to be able to freely move up and down should your vehicle be upside down for a long time.
--"U Ain't Fast!!"
Old 08-15-2009, 03:08 PM   #4155
Hitec 7955 and about 5 gallons with no problems. They're definately worth the money
8ight-T 2.0, Werks .21 B7 PRO, DX3R ,Hitec 7955's
Losi Strike
steve307b is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Forum Jump
Tekno RC 1/8th Scale Brushless Conversion Thread teknorc Electric Off-Road 2229 Today 04:42 PM
8IGHT 2.0! BAUSTIN Nitro Off-Road 3746 Today 04:35 PM
GRP... Engine... Thread... xlgraphicspro Nitro Off-Road 1912 Today 09:41 AM
OS Speed V-Spec II question Frank L Nitro Off-Road 32 05-20-2009 10:50 PM
Don't buy MP9 Dale14 Nitro Off-Road 155 03-07-2009 08:28 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
