Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-12-2009, 10:53 AM   #3541
bphil49's Avatar
Are any of you guy's having trouble with rear shock ends coming off? Even after you replace the factory ones?
bphil49 is offline   Reply With Quote
Old 07-12-2009, 11:10 AM   #3542
sugelle's Avatar
Trader Rating: 16 (100%+)
Check the threads on your shock shafts and make sure they are OK. When I got mine from the factory, the shock ends were stripped and this left melted plastic in the threads. I cleaned them with a small wire brush and then installed the new shock ends. If that is OK, I woudl also recommend checking your droop to ensure you got the proper amount and not more.
Joe E
Live every day as if it were your last, because one of these days you will be right
sugelle is offline   Reply With Quote
Old 07-12-2009, 11:16 AM   #3543
Frank L's Avatar
Trader Rating: 15 (100%+)
On e I replaced them I have not had any issues at all and I run a stock setup.
- BCE 8ight T 2.0 - OS Speed II - DX3R - Hitec 7950 - 7940
- BCE 8ight 2.0 - OS Speed II - DX3R - Hitec 7950 - 7940
- powerhousercperformance.com <<Engine Mod Magic<<
- coldfusion fuel - www.coldfusionrcproducts.com -
- carolinasrc.com -
Old 07-12-2009, 12:31 PM   #3544
have you checked yur droop? my shock ends were stretched bad, checked and droop was 132
randystang is offline   Reply With Quote
Old 07-12-2009, 12:36 PM   #3545
has anyone tried any of the lighter springs or different rear setups
Old 07-12-2009, 12:48 PM   #3546
TIX
TIX's Avatar
i tried the changes casey mentioned and it made the car very loose out of the corner at the track i was at on the weekend.
i started the day with all the changes and pulled them off 1 by 1 during the day until all that was left was the softer white springs. i liked the softer springs so ill keep them.
im going to give the changes a go at another track to see if they work better there
TIXrd - Race Designs & Concourse Bodies
Losi 8ight 2.0 - BCE Speed - RB WS7III L2G, TT 2035
Losi 8ight-T 2.0 - BCE Speed - RB C6BBT L2G, RB 2045/198
Hitec servos, AKA Tires, Purple Rush 30%
TIX is offline   Reply With Quote
Old 07-12-2009, 12:52 PM   #3547
I had one come off in a Pro series race with 3 min to go, running 3rd and moving to the 2 leaders. The worse possible time. I installed jammin short rod ends that are intended for 3.5 mm shafts. They aint commin off. You will most likely need a shock shaft tool to install them but they work perfectly. I just saw 4 people having this problem with big jumps and I even saw some one running red aluminum ones at a recent race.
crazysavage is offline   Reply With Quote
Old 07-12-2009, 01:39 PM   #3548
Default shocks off
I used to always have this problem so I just replaced all my shocks with Kyosho big bores (80 bucks front and rear from ebay)- I have yet to break em
vales1 is offline   Reply With Quote
Old 07-12-2009, 02:45 PM   #3549
JAMMINKRAZY's Avatar
Never had an issue with the shock ends. If your droop is set correctly, they should be fine, unless you have a bad impact.
As for my experiences with the Casey Peck setup, I ran the truck with it yesterday with great results. I used the front links as I mentioned earlier, and a 2mm sway bar. I stuck with the stock grey springs and oil. My findings were that the truck had substantially more turn in, and the rear end stayed very planted. I did notice slightly less on power steering though. For me, and my driving style, the chenges were very beneficial. My next change will be to try the white rear springs, but I really liked the way it was.
Losi 8ight 2.0 - OS SPEED - RB S5 L2g - Hitec TG servos
Losi 8ight-T 2.0 - Ninja JX - OS v-spec - Hitec 7940TH - 7950TH
Spektrum DX3R -------- Team Terribles-------Ridgeway Bodies
***Carolinas RC***
JAMMINKRAZY is offline   Reply With Quote
Old 07-12-2009, 03:16 PM   #3550
Integra's Avatar
vladconnery im Stumped as to your bone problem....i would suggest taking stuff apart and get measuring ......get out a set of caliper's and just start measuring w/e you can....im sure you'll find out the issue.
Blue Groove Apparel - Hitec - Losi - W.E.D. Paint - Byrons Fuel - O.S. Engines - Tekin - Futaba - Clockwork Engines Team Driver - Matrix Concepts.
Integra is online now   Reply With Quote
Old 07-12-2009, 03:45 PM   #3551
Originally Posted by vladconnery View Post
Have any of you guys ever seen this. One of my front shafts does not reach into the out drive fully. Causing it to pop out.
1. the diff is a center smart diff converted over to a front.
2. I thought it was the aluminum spindle and carrier. Changed it back to a plastic still the same. To eliminate bad aluminum milling.
3. there is not back and forth play in the shaft.
4. there is not back and forth play in the diff or out drive.
5. droop is 110mm not that. it should make a difference.
6. It's a new shaft I took the original out and replaced before the pick. To eliminate short or bent shaft.
7. It's the shaft on the right FYI.
thanks in advance for your thought and ideas.
Attachment 475286
Attachment 475287
Check your diff cup,The metal peace that the flanged bearing rides on has moved in.That will make the outdrive look shorter.
white48rc is offline   Reply With Quote
Old 07-12-2009, 06:57 PM   #3552
what to do to improve traction on a loose dusty track, that can be changed back for high grip once night falls fairly easily.
Old 07-12-2009, 07:17 PM   #3553
I just got my T2.0 and it has grey fiber/pastic disc brakes on it and they are the same size front and rear. I called Losi and they didn't know if they were right or not. they dont have any holes to vent either. Has anyone else seen these brake rotors. Im guessing it is some kind of update because it also came with a fuel tank pull strap and the front and rear camber screws are plenty long and go all the way through the lock nut on the other side.
Panther Products
Team Trinity
E.B. Mods
Mark K is offline   Reply With Quote
Old 07-12-2009, 07:34 PM   #3554
aaron joy's Avatar
Trader Rating: 5 (86%+)
Mark I think you got the hobby hut edition.
Aaron Joyce
Team Boca Bearings, Integy, Chick's Hobbies
aaron joy is online now   Reply With Quote
Old 07-12-2009, 07:39 PM   #3555
whys that Aaron?
Panther Products
Team Trinity
E.B. Mods
Forum Jump
Tekno RC 1/8th Scale Brushless Conversion Thread teknorc Electric Off-Road 2229 Today 04:42 PM
8IGHT 2.0! BAUSTIN Nitro Off-Road 3746 Today 04:35 PM
GRP... Engine... Thread... xlgraphicspro Nitro Off-Road 1912 Today 09:41 AM
OS Speed V-Spec II question Frank L Nitro Off-Road 32 05-20-2009 10:50 PM
Don't buy MP9 Dale14 Nitro Off-Road 155 03-07-2009 08:28 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
