Matt .. i have run both smarts and loved the way it went but i am getting a lot of pizza cutting on the the front tyres so i was gonna try running just the front to see the results. Have you tried just the front?
Try removing two springs from the center diff and running just two .15s. That's what I'm running, and I really like it. I think a few of the pros are running that setup, and some are even cutting a few coils off of the two remaining springs.
Haven't personally tried a smart diff in front yet.
-Howard
Hi Howard
I am running it like that now mate as well , with good results
Team Losi 2.0T
Novarossi Plus 4
Futaba Fasst
I know its probably been posted many times, but my 8t 2.0 seems to push more so when I turn to the left then the right,(still does to the right), and I have to brake quite a bit to get it to turn tight. Can anyone make some ajustment sugestions, to get it not to push so much. I pretty much have it set up per the losi set up sheet in the manual. Thanks in advance
Reduce the rear to-in from 3.5 to 3
Donny Vinkemulder
Team Losi
8ight 2.0 - OS Speed w/2050 - Futaba 3PK Super - Nitrotane VP 30% - Losi Lipo Batteries - AKA Tires - XXX-CR
Special thanks to: Dynomite, Adam, Todd, and Kevin
+1 on the 3 degrees in the rear. I run a king headz 3-3 block and 5k in the rear and it seems to work good.
+2 on the 3-3 block. I just bought the 2-3 block and am going to try it next. On a loose track where the front tends to push this maybe the ticket. Also going to try a little less front droop.
Finally took the plunged and joined the 2.0 club. Now I'm just asking myself why did I wait so long. This Truggy is much better in than the 1.0. Finally somebody put out a car Buggy or Truggy with definite improvements. Anyone have any advice for me or watch out for's?
I'm running
Jammin JPX .21 (JP4)
steering JR 9100T
Throttle JR 9100S
Smart Diff center
Contemplating smart diffing the front as well.
Side note I was using the Losi lipo and regulator. For whatever reason it started making me lose connections. Went back to NImh packs no more problems. Just in case anyone runs into the same issue.
Futaba 3PK Faast
LOSI 8IGHT 2.0T
Jammin JPX
"My Losi is my SWORD and I shall wield it with no reguards to life or limb."
i like the stiffer rear sway bar more because here in europe are more technical tracks with more corner speeds, i need the car more stabel and thats the reason why i put the 3.00 sway bar from the 1.0 buggy in my 2.0 truggy
