Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-24-2009, 07:02 AM   #3241
JAMMINKRAZY's Avatar
Originally Posted by Frank L View Post
I have noticed that no matter how much i clean and polish the hinge pins they still bind in the arm pretty hard. The pins rotate freely in the hinge pin retainers so why do they need to be free in the arm too. My suspension does not bind the pins just don't move in the arms very much they rotate at the ends where the retainers are. What is wrong with this? It keeps the slop down and the suspension works well.
I agree. They do wear out the toe blocks (or if you have the Adj. ones, the inserts) faster that way, but they will never wear the arms out. I would rather change retainer inserts than arms frequently. Just my take on the so called binding issues.
Losi 8ight 2.0 - OS SPEED - RB S5 L2g - Hitec TG servos
Losi 8ight-T 2.0 - Ninja JX - OS v-spec - Hitec 7940TH - 7950TH
Spektrum DX3R -------- Team Terribles-------Ridgeway Bodies
***Carolinas RC***
JAMMINKRAZY is offline   Reply With Quote
Old 06-24-2009, 07:18 AM   #3242
mattwoodcraft's Avatar
thats why i just ppolished them not to make them perfect i guess but to elimnate any sought of bind that may affect a long race
your correct what you say it is cheaper buying inserts rather than arms but the rear arms dont wear any faster by trying to make the pin slide through easier.
RYPER HOBBIES ~ PURPLE RUSH FUEL ~AKA TYRES
GO TECH MG66 ~ BCE CHASSI
X-ray 808 09 spec
mattwoodcraft is offline   Reply With Quote
Old 06-24-2009, 08:19 AM   #3243
Making the pin slide through easier or rotate in the arm easier WILL make the arm wear faster. If the pin is rotating in the arm while running, the arm will wear. If it is rotating in the inserts, the inserts will wear. Something has to wear. I prefer it to be the inserts, as they should be changed regularly anyway. As you said they are also lots cheaper than arms are.
***Carolinas RC***
Old 06-24-2009, 08:41 AM   #3244
Frank L's Avatar
Trader Rating: 15 (100%+)
Well on my truck I run the fioroni hinge pin braces and they are not cheaper then the arms. I have had the truck since it was released and I race 2-3 weekends per month, the option parts were installed from the beginning and the fioroni hinge pin braces have not wore out or developed and slop. I believe that you get what you pay for.
- BCE 8ight T 2.0 - OS Speed II - DX3R - Hitec 7950 - 7940
- BCE 8ight 2.0 - OS Speed II - DX3R - Hitec 7950 - 7940
- powerhousercperformance.com <<Engine Mod Magic<<
- coldfusion fuel - www.coldfusionrcproducts.com -
- carolinasrc.com -
Old 06-24-2009, 09:41 AM   #3245
Suspended
Trader Rating: 67 (99%+)
Well I did all the fixes and followed you guys with this for a long time Frankl and Integra and others but I am now selling mine.. I got bit by the brushless bug LOL Thanks for all your help everyone when I had issues or needed to find better ways to fix things. They are the sweetest truggies on the market but I want to try something else for awhile.. If I could afford to go BL in it I would keep it and do that but I don't have the money for it so it's gotta go.. I still got my buddies BL 8ight t 2.0 sitting here so I can run it ..
jldjlaudio is offline   Reply With Quote
Old 06-24-2009, 09:43 AM   #3246
MattOCM's Avatar
Default 8t vs MBX 6t
I have been out of rc for about a year and raced both buggy and truggy and want to get back in and looking to just race truggy. Can anyone give me a unbias pick on the mbx 6t vs the losi 2.0 truggy. coming from running a strr truck and rc 8 buggy.
Thanks in advance
Matt
MattOCM is offline   Reply With Quote
Old 06-24-2009, 10:00 AM   #3247
Frank L's Avatar
Anythng will be a great improvement over the K truck. I went from a str to a losi 8t 1.0 mstly because I was tired of the str always being broken and the parts were difficult to get. Another factor was my LHS owner made me a smoking deal on the 8. I loved the losi from the beginning and I now have a 2.0. The truck and buggy can take the same started box and they have alot of parts in common. I love my 2.0. Mugen has been in the 1/8 scene for a long tim. They make very high quality cars. It is interesting to me how much the mbx6t and the 8t 2.0 share in common. Their bodies have similar lines the f/r ride heights are exactly the same handling seems to be similar and I am sure I have missed something. Either losi or mugen will treat you right.
- carolinasrc.com -
Old 06-24-2009, 10:01 AM   #3248
jzemaxx's Avatar
Thanks in advance
Matt
If you want un-biased it won't be in this thread...lol.
Mugen MBX6-T NEU/MMM, Mugen MBX6 NEU/MMM, Losi 8B 2.0 NEU/MMM, Losi 8T 2.0 RR NEU/MMM, Losi 8T 2.0 RTR NEU/MMM, Losi LST2.0 NEU/MMM
jzemaxx is offline   Reply With Quote
Old 06-24-2009, 10:09 AM   #3249
i used to race the mugan but had to try the losi and never really have looked back ... frank is rite about the mbx6t these two truggies are great it would be a personel thing i would go losi .... but the mbx6t is nice truggy to drive
X-ray 808 09 spec
Old 06-24-2009, 10:15 AM   #3250
jzemaxx's Avatar
I have looked at the MBX6-T and it resembles the RC8T to me. The wheelbase on the RC8T with the hub back is 375 just like the mugen. Also the rest of the physical size appears the same even the chassis look similar. The only thing that separates them is the diff fluids and ride height.
Old 06-24-2009, 10:25 AM   #3251
shady3031's Avatar
Trader Rating: 16 (100%+)
Thanks in advance
Matt
I too switched from kyosho to the losi and will never go back. Got so tired of always shimming diffs and also had some issues with front arms-i have not driven the mugen but I have seen a couple arms break, they look good. I do have a good buddy that has driven my truck and took a few laps with the mugen and said they drive close to the same. Seems to me the biggest difference would be the losi hubs compared to the pillow ball mugen setup-which one suits your style better. Also withthe losi parts are gonna be in abundance
I see the ocm in your avatar. Alan burton is the one that got me to try the losi and it has been great!!! I am so much faster and consistent with the losi truck
Losi 8T 2.0 with a powerhouse modded extech 24 ballooning the tires!!!!!
New house toy 1/16 vxl revo on 4s with one broke front axle shaft and many more to come
Special thanks to my wife and family
shady3031 is offline   Reply With Quote
Old 06-24-2009, 12:53 PM   #3252
Trader Rating: 32 (100%+)
quick question can some one educate me on why the losi runs a 0 offset and the old one ran a 1/2 offset. and what is the difference of them both i am not sure what it means and what the difference in them are( offsets) . any info would be great thanks again rctech!
HB Ve8 !! (Team Driver : $TMoney$)
HotBodies D4 Tekin rs 13.5
Silent Assassins 1/8th Racing Team!
rhino420 is offline   Reply With Quote
Old 06-24-2009, 12:59 PM   #3253
losi_racer's Avatar
i dont know if this is 100% correct,so dont quote me
losi went to longer a arms so do offset this they went to 0 off set wheels, because roar has limits on length and width and truggys are pretty close to this.and also almost all companys go with 0 offset wheels anyway
Losi 8ight-T 2.0/ Nova +4/ Ofna 053/
Losi 8ight-B 2.0/ Nova +4/ 9853
One Hobbies/ The Nitro Pit/SRS/ BCG Industries/ Team Terribles
losi_racer is offline   Reply With Quote
Old 06-24-2009, 01:00 PM   #3254
the arms are shoter on the 8t so they had to put 1/2 off set wheels on it to compensate
on the 8t 2.0 the arms are longer so the run 0 off set wheels to compensate
-MUGGIFIED-LST2-teal427
-jr/hitec servos
-8t 2.0-ninja jx21 -ebmods head button
-speed crank
-futuba brushless
reggie l. is offline   Reply With Quote
Old 06-24-2009, 01:01 PM   #3255
so the offset just make the truck wide which i assume makes it handle better? is that the reason for offsets? so if i run 1/2 offsets my truck should handle a little better since its wider? well maybe not handle better but be more stable?
Forum Jump
Tekno RC 1/8th Scale Brushless Conversion Thread teknorc Electric Off-Road 2229 Today 04:42 PM
8IGHT 2.0! BAUSTIN Nitro Off-Road 3746 Today 04:35 PM
GRP... Engine... Thread... xlgraphicspro Nitro Off-Road 1912 Today 09:41 AM
OS Speed V-Spec II question Frank L Nitro Off-Road 32 05-20-2009 10:50 PM
Don't buy MP9 Dale14 Nitro Off-Road 155 03-07-2009 08:28 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
