Old 12-10-2008, 07:35 PM   #136
Trader Rating: 44 (100%+)
this sucks I've gotta wait even longer lol...hopefully i get one ready and built before the 24th of next month
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 12-10-2008, 07:46 PM   #137
BigC123's Avatar
It wont be long.
Clayton "BigC" Neal
Caster Racing USA
SpecR R1
XRAY T3R
Speed Passion USA
BigC123 is offline   Reply With Quote
Old 12-18-2008, 09:20 PM   #138
slaytanic's Avatar
Trader Rating: 20 (95%+)
8 days since the last post in the CORRECT Caster thread. Let's bring it to the top and get rid of all the other garbage.
Mike, I see you guys have a c hub conversion? Whats the deal. Is it just a preference thing or do you feel it improves the buggy?
Has the diff/pinion design changed at all in the new design?
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 12-18-2008, 09:29 PM   #139
skeller's Avatar
Send a message via AIM to skeller Send a message via MSN to skeller Send a message via Yahoo to skeller
I'm not Mike...but I think I can handle most of this one.
That I know of, only one guy in the USA has ran the Caster c-hub conversion. We currently have 3 or 4 guys that have ordered them to try out. I will also try one out soon.
The diffs in the new buggy are helical cut with tighter tolerances than the old version. They should be the same gears that are currently sold in the electric Fusion buggy.
skeller is offline   Reply With Quote
Old 12-18-2008, 11:15 PM   #140
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
The new gears in the fusion pro are sweet. i dont think there will be any issues with them
cheesecake is offline   Reply With Quote
Old 12-18-2008, 11:17 PM   #141
also the c-hub is a option for people to try i have a feeling after they run it they will like it but lap times compared to the pilloball will be affected. with the pillowballs you can get through the rough sections faster
and slaytanic if i get to leisure you can give my fusion pro a whirl around the track
Old 12-19-2008, 03:31 AM   #142
slaytanic's Avatar
No way man. You'll put bad Ju-JU on my Xray! You are too good to hang out with us Nitro boys now anyway!
JFWY!
I saw Cam's down in Alvaredo and it looked sweet! I don't think I like pillowball all that much too tell you the truth. Nice to have an option!
Team Epic
Old 12-19-2008, 04:43 AM   #143
vnmsgt's Avatar
So just the Fusion PRO has helical cut gears and the 1.5r should? My Fusion sport does not have helical gears but they are different than a ZX1-R.
Check out www.holeshothobbies.com
Now offering support for: Agama, Caster, Serpent, Mugen, HotBodies,VP PRO, Answer-RC and much more.
vnmsgt is offline   Reply With Quote
Old 12-23-2008, 04:27 PM   #144
vnmsgt's Avatar
Just got my 1.5R in today Will post some pics as I build it so everyone can see. You can definetly see the quality is a step above what it was. Ring and pinions are slightly bevel cut now. Steering turnbuckle rod ends are not captured and the plastic ball ends are alot thicker. The wing mount is completely different and seems longer and higher. Also the Chassis actually has ZX1.5R engraved in bold letters on the bottom of the chassis. Diff orings are orange now and you can tell thicker then the old ones and should solve any diff leaking issues from the past.
Old 12-23-2008, 04:43 PM   #145
Dude C.'s Avatar
lucky you. Look forward to seeing pics. My 1.5 is in limbo somewhere as the tracking # doesn't work but I'm sure it'll make it sometime.
It's hard to soar with the eagles when your surounded by turkey's!
COBRA CAT KILLER!!!!
Dude C. is offline   Reply With Quote
Old 12-23-2008, 06:50 PM   #146
Trader Rating: 14 (100%+)
Dang Chris I havent even got my 1.5 yet! LOL Oh well What I have now is close enough Will have pics on caster site latter tonite. Get those 1.5 pics on here asap!!
"Peasey"
Special thank to my sponsors.
Airtronics, Rc Country Hobbies, Rc Renew, Triton Engines, Lutz Rc
Josh Pease is offline   Reply With Quote
Old 12-24-2008, 08:30 AM   #147
vnmsgt's Avatar
I am at work right now but can post pics later this evening. This thing is sweet. The diff gears look WAY BETTER and are slightly bevel cut ring and pinions. NO NEED FOR SHIMMING the diff in the bulkhead, FITS PERFECT. The ring and pinions are so smooth now it ain't even funny. The outdrives look the same but the shafts that go into the diff case are slight shorter and also the pinion gear looks like the toughest one I have ever seen, Also is lighter too with a huge hole drilled in the center. Front shock tower is alot shorter therefore you can get alot more droop and the holes are alot closer together which will lay the shocks down more. Servo saver threads are alot more course and will prevent stripping of it like what was easy to do on the previous model. Hinge pins look alot harder and are different color. Steering rod ends are captured and the plastic ball end is way thicker and stronger so should not break anymore. Also no need to put spacers under the ackerman plate ball or knuckle one to get rid of bumpsteer as the new captured ones sit on a post and automatically to this for you. That is all I can see as of now. I will post more later as I find out.
BTW Think we should make a new thread that just says Caster Racing ZX1.5R? This one just says new buggy announced. Or can we change the name of this thread somehow which I think would be better.
Old 12-24-2008, 09:07 AM   #148
Dude C.'s Avatar
Pm the moderator if the thread name is to be changed. I think hes the only one that can do that.
Old 12-24-2008, 10:40 AM   #149
vnmsgt's Avatar
Who's the mod?
Old 12-24-2008, 11:31 AM   #150
Dude C.'s Avatar
Who's the mod?
Go to list of forums and at the bottom. It's Mr. Losi is who ya need to contact.
