Old 11-21-2008, 01:29 PM   #1
Default New to nitro with a used buggy. Questions
I just recieved my first nitro car, a used Mugen MBX5 off of ebay. I want to do a complete teardown of the car and clean everything. Is there a special way to take apart the engine (O.S. 21VG) and clean it out or can I just clean it with warm, soapy water and compressed air?
karter15 is offline   Reply With Quote
Old 11-21-2008, 01:39 PM   #2
Fluke's Avatar
i wouldn't use water. A little bit of fuel, alcohol and wd40 should work
Fluke is offline   Reply With Quote
Old 11-21-2008, 02:01 PM   #3
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
fuel works well to clean motor parts...
jamminnay is offline   Reply With Quote
Old 11-21-2008, 02:17 PM   #4
simple enough. thanks guys. Now what about bearings? I'll probably just completely replace the ones in the buggy but I need to learn sometime.
Old 11-21-2008, 04:52 PM   #5
Mlbracing's Avatar
This is what I'd recommend doing if your new to nitro
buy a new clutch and learn to put it together
read up on engine temperatures and low end and high end needles
and just give the buggy a good bath after every race with simple green, an air compressor and a brush, just make sure to take the engine off first, no simple green on the clutch
~ Team Associated ~ Jconcepts ~ Byrons Fuel ~
Thanks to my dad and everyone who helps us out!
Mlbracing is offline   Reply With Quote
Old 11-22-2008, 04:06 AM   #6
Mark_Australia's Avatar
Hey guys what is simple green?
I see it recommended in other threads.... I figured it was a degreasing fluid but if people specifically recommend simple green what is it about that product?
PS I'm just blowing it out then using a brush and methylated spirits on the greasy bits
Mark_Australia is offline   Reply With Quote
Old 11-22-2008, 04:20 AM   #7
Chill_Will's Avatar
Trader Rating: 32 (100%+)
It's a all purpose cleaner. Cleans really well and safe on most surfaces. Non Toxic. Biodegradable, non flammable and non corrosive.
Chill_Will is offline   Reply With Quote
Old 11-22-2008, 07:08 AM   #8
LabRat99's Avatar
www.simplegreen.com
Don't know if it's available outside the US though...
LabRat99 is offline   Reply With Quote
Old 11-22-2008, 07:17 AM   #9
LabRat99's Avatar
I never use water on my buggies... I clean with compressed air, picks, and brushes.
Things I pull off of it during teardowns get thrown in a bucket of 50/50 simple green and water ( I remove any bearings first ).
I'd go through the buggy looking for stripped plastic and replace all the screws with a high quality screw kit ( like Tony's Screws ).
Good luck and have fun with it!
Old 11-22-2008, 07:26 AM   #10
RickBac's Avatar
Trader Rating: 20 (100%+)
Simple Green is a far safer cleaning product than, brake cleaner, motor spray, gasoline, etc.
It is water soluble. It cleans almost as well as the alcohol/petroleum based products.
I have seen it slightly grey some plastics.
If you are outside the US and can not find simple green, I assume you have something similar available.
Losi XXX-CR
LRP Sphere Brushless
HB D8
Trinity .21
Airtronics
RickBac is offline   Reply With Quote
Old 11-22-2008, 07:34 AM   #11
rced1's Avatar
Trader Rating: 17 (100%+)
In addition to the other good suggestions I would add, keep the cleaning solutions away from the electronics (servos-receiver-etc.); besides fuel denatured alcohol is good for cleaning the inside of an engine, and remember to lube the inside with after run oil or mineral oil (engines with epoxied cranks) on assembly.
rced1 is offline   Reply With Quote
Old 11-22-2008, 07:34 AM   #12
moeman's Avatar
Trader Rating: 26 (100%+)
I find a spray can of foaming window cleaner works great . The ammonia cuts the grease, and blow it off with compressed air. Isopropol 99% works great too.
moeman is offline   Reply With Quote
Old 11-22-2008, 07:37 AM   #13
CanyonCarverR1's Avatar
Be careful using compressed air, it's really good at pushing dirt into bearings!
Personally I use a brush and some Serpent Cleaning Gum.
For the engine, I tear it down after every day of racing or practice.
Here's the steps I use:
Remove the clutch
Cover the intake and exhaust ports
Spray off the exterior of the engine with Nitro Wash, or similar
Remove the glow plug
Remove the back plate
Remove the head
Remove the sleeve
Remove the piston
Push out the crank
Spray everything off with Nitro Wash
Inspect all parts, especially the piston and sleeve
Coat all parts with Mugen Engine Maintainence Oil, or other light oil
Make sure to coat the bearings
Re-assemble in reverse order
Following this regiment will properly maintain your engine, and you will spot problems before your engine blows up.
Hope this helps
CanyonCarverR1 is offline   Reply With Quote
Old 11-22-2008, 08:48 AM   #14
also when your at the track and everyone is using simple green between runs... i use wd-40 and blow it off with the air compressor rather its right or wrong i woult say i think its right because simple green degresses your berings and wd-40 dosent so makes more since to me
ruggydriver is offline   Reply With Quote
Old 11-22-2008, 09:03 AM   #15
AlanHall's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
yeah getting WD in a gallon and putting it in a bottle works good..and coats and protects everything nice..
Alan Hall
AlanHall is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
Major Sell Out......All Must GO!!!!!!!!!! ovalnator R/C Items: For Sale/Trade 30 07-20-2008 03:18 PM
Northwest Championship Tour, I B RACIN Northwest Racers 1297 05-13-2007 07:11 PM
Nitro Sell-Out MP777/M8/DSM/RB Concept, etc. youthmanrcer R/C Items: For Sale/Trade 10 10-10-2006 01:51 PM
2006 Dash for Cash Series @ Dirt Heaven in Green Bay, WI (BIG PAYOUT!!!) Brandon Rohde Wisconsin & Illinois Racing 146 09-18-2006 10:54 AM
