Old 11-20-2008, 07:17 PM   #1
Default Tuning buggy suspension
I just purchased my first 1/8 buggy, a hyper7pbs from woodman.
It runs great, I had lots of fun with it today the way he had it set up.
One thing i've noticed is that it understeers severely while braking - if I nail the brake and turn, it just continues in a straight line until it stops. If I let up on the brake and nail the gas it will slide through the turn like it should
Is this how all 1/8 buggies are, or can I adjust this out with the brake bias?
I'm assuming I want the front brake to engage later, so I would adjust the linkage to engage later, but maybe i'm all backwards.
Mark
mud99 is offline   Reply With Quote
Old 11-20-2008, 07:28 PM   #2
mugenb46's Avatar
Mark
your headed the right direction, brake bias is key on cornering during breaking, also be sure to have the proper diff oils in, i always start off with this.
front=5
center=7
rear=2
this will be in tyhe ball park of most common setups, and you can then get a good feel on the car, but your looking for more rotation through the turn so reduce front bias, and you will feel the change right away.
Brian Carey
Pro Twister Mods
brian@protwistermods.com
615-838-5373
mugenb46 is offline   Reply With Quote
Old 11-20-2008, 07:31 PM   #3
You can also check your servo saver to see if it's tight enough,if it's too loose the car won't turn..
Hixie is offline   Reply With Quote
Old 11-20-2008, 07:34 PM   #4
Trader Rating: 61 (100%+)
i had this attachment here ...if you need any other info on what every adjustment does and how it effects the handling ...when i set up my first 1/8th scale i used this as a guide ...mbx has got you going in the right direction on diffs ...hope this helps....
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 11-20-2008, 07:42 PM   #5
mblgjr's Avatar
Trader Rating: 86 (100%+)
Almost sounds like you have too much front brake bias and the front tires are locking (thus you continue to skid straight instead of turning).
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 11-20-2008, 08:08 PM   #6
I can only add its not really when the brakes apply in relation to each other as they will feel almost simultanius due to their design limitation. Bias is used to describe how much brake force is applied in relation to each other. I didnt read the provided link but most of the people I know have the rear brakes set stronger than the fronts. The main thing you dont want is too much front as the rear will lift & you'll flip or the rear will snap around at the end of a long straight. Rember if you set it(bias) right on the edge earlier in the day when the track is in good shape it will be too much for the end of the day when the track gets rutted & form braking bumps at the end of the day & if you use end point adjustment to get rid of that you may not have enough total brake when you need it most.
butch man is offline   Reply With Quote
Buy / Sell BoardSlapper Canadian R/C Scene 11025 08-15-2017 08:02 PM
toe-in and toe-out asbe88 Electric Off-Road 16 04-05-2015 06:50 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 01:50 PM
Robitronic Mantis For Sale $350 OBO Briguy R/C Items: For Sale/Trade 10 10-07-2007 05:37 PM
