Old 11-18-2008, 01:44 PM   #1
losi_racer's Avatar
Trader Rating: 25 (100%+)
Default install clutch tips
i have a losi 8ight b and i am installin a new clutch but im havin problems puttin the bolts thru the spring and into the hole in the flywheel, anyone have any tips
losi_racer is offline   Reply With Quote
Old 11-18-2008, 01:52 PM   #2
You can either round the ends of the bolts down to help them slide in or i just squeeze the shoes slightly into the flywheel using pliers while pushing the bolt into place
Its easier to fit the plastic shoes first till you get the feel of it but you'll soone get the hang of it
losi8lunie is offline   Reply With Quote
Old 11-18-2008, 02:13 PM   #3
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Just squeeze the shoe in a bit so the screw can go through . Once you do it a few times it seems easy .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 11-18-2008, 08:41 PM   #4
Integra's Avatar
the 2.0 clutch pins have been pre rounded for our convenience...but like bri said just push on the shoes a bit and it'll go through and be second nature soon enough.
Old 11-18-2008, 10:49 PM   #5
Fletcher6371's Avatar
Get ALL of the shoes/springs/ pins STARTED. So basically the pins are not to the threads yet. Then put a ziptie around all the shoes. Pull TIGHT. Pulling the ziptie tight will pull the shoes together around the center and allow for the pins to basically fall right in. (although rounding the pins will work also)
FlatBusted Racing
Dialed Inc., North Central Hobbies, Competition Heat, FUnS Racing lol
Fletcher6371 is offline   Reply With Quote
Old 11-18-2008, 11:30 PM   #6
losi_racer's Avatar
ok well, i got the shoes installed, the new bearings and the new cb, i used the spacers and right now i have 2 between the flywheel nut and the bearing and one between the front bearing and the cb screw, but there seems to be more play then there should be but if i move the spacer from the back to the front it has NO play at all and it is rubbin. should i keep it how it is or what because i have no more spacers
Old 11-19-2008, 06:44 AM   #7
Briguy's Avatar
Do you have the washer between the collet and engine ?
Royal R/C & Hobby
Old 11-19-2008, 11:34 AM   #8
losi_racer's Avatar
what washer. i even just looked at the exploded views.i see no washer
Old 11-19-2008, 12:08 PM   #9
Briguy's Avatar
The washer that comes in the clutch parts bag .
http://www.losipartshouse.com/servle...llet%2C/Detail
Not sure why it is not shown in the exploded view .
Royal R/C & Hobby
"the tuning bible" houston Onroad Nitro Engine Zone 311 04-24-2017 11:18 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
Yay Dvx400Rider Nitro Off-Road 7 02-27-2009 08:25 PM
Please Help Muah! Speedjunkyz Nitro On-Road 36 09-05-2008 07:13 AM
Race Settings dieseldog20 Monster Trucks 16 01-24-2008 10:26 AM
