Old 11-20-2008, 12:28 PM   #16
T$
T$'s Avatar
Originally Posted by Franchize04 View Post
I ordered one of these yesterday 149 with 10% off code and free shipping= $134.99 shipped. I believe this is a newly release engine that is made up of the older discontinued parts. I believe this engine has the 13mm crank regardless of what it says. And that carb in the picture is the same carb as the P5. The 3 port economy engines don't come with that carb so Im not holding my breath on receiving that carb. Im sure it will come the cheaper(non venture) carb shown in the BF2001 picture. Either way, can't beat $135
When you receive it, if you would let us know some of the details that would be great.
T$ is offline   Reply With Quote
Old 11-20-2008, 12:49 PM   #17
The 3 port limited edition comes with the standard nova carb that accepts inserts and uses the old style P5 case so it has the larger rear bearing. I do not know if it has the 14mm or 13mm crank though.
mbrienzo is offline   Reply With Quote
Old 11-20-2008, 01:11 PM   #18
COBRARACING's Avatar
Originally Posted by rced1 View Post
This question has been asked before on RCTech:
NovaRossi N21B 2000 or 2001 BF?
The difference is a 14mm crank instead of the 13mm with the 2000 and a higher heat sink thats all.limited edition i dont think so .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 11-20-2008, 03:29 PM   #19
The limited edition is a small run of mills that they have put different carbs on and used different cases. Unless you have seen one come out of the box that has the LIMITED EDITION sticker on it I would reccomend checking one out before you post your opinions
Old 11-21-2008, 06:50 PM   #20
ade
ade's Avatar
Trader Rating: 22 (100%+)
I noticed they mentioned 25% nitro. Is this the limit? I usually run 30% and wanted to stay with that. I plan to use it for indoor racing season here in Michigan. 3 ports should be fine for small-medium size track.
Thanks.
ade is offline   Reply With Quote
Old 11-22-2008, 05:20 AM   #21
drs92's Avatar
Trader Rating: 36 (100%+)
Send a message via AIM to drs92
so which is better?? and are they better then a go-tech 3 port race spec turbo plug????
drs92 is offline   Reply With Quote
Old 11-22-2008, 07:54 AM   #22
rced1's Avatar
Trader Rating: 17 (100%+)
Thanks.
I interpret this as no more than 25% nitro in stock setup. Add an extra head shim and it should be fine for 30%.
rced1 is offline   Reply With Quote
Old 11-22-2008, 08:02 AM   #23
Trader Rating: 66 (99%+)
ANY Novarossi is better than a Go
pwnzor is offline   Reply With Quote
Old 11-22-2008, 08:02 AM   #24
ade
ade's Avatar
I was thinking the same- shimmed from the factory for 20-25%. I guess you cant beat the price! Mine should be here next week.
Old 11-22-2008, 08:14 AM   #25
I run my 2001BF on 30% and I haven't installed and extra head shim nor have I had any detonation but I think it really depends on your elevation and where you live.
x195svt is offline   Reply With Quote
Old 11-22-2008, 07:50 PM   #26
I got lucky and just ordered the last one Amain had, they are now on backorder
Old 11-23-2008, 07:25 AM   #27
ade
ade's Avatar
I live/race in Michigan. no real elevation here. I'll install an extra thin one to be on the safe side.
Old 11-24-2008, 10:22 AM   #28
Franchize04's Avatar
Trader Rating: 39 (100%+)
I got my 2000 limited today and it has does have the good carb with the insert and the big bearing case like the P5 so its all good
No sponsors needed: Team Run What I Want
Hot Bodies D812 * RC10B5 *Novarossi* Spektrum * Protek *
Franchize04 is offline   Reply With Quote
Old 11-24-2008, 12:58 PM   #29
T$
T$'s Avatar
Cool, thanks for the update Franchize04
Old 11-24-2008, 06:59 PM   #30
Kyosho Kid's Avatar
I just picked up a 2001 BF and i have that same carb but my case looks a bit different. so i guess its the crank and bearing that is different....and it doesn't say "Limited" on the head.
Kyosho Kid is offline   Reply With Quote
