Old 11-17-2008, 05:47 PM   #1
AlanHall's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to AlanHall Send a message via Yahoo to AlanHall
Default bearings.
what do you guys say makes a "good" bearing..not your fav. brand.. but .. the type of shields? the metal? im talking engine,clutch,diffs. everything.. i work for a fastener distributer and have acces to some great prices..and was thinking about stocking up..maybe selling some as well.. but i really dont know what im looking at ...
Alan Hall
AlanHall is offline   Reply With Quote
Old 11-17-2008, 06:23 PM   #2
Trader Rating: 21 (100%+)
Stock rtr brgs are usually cheapies and are always metal seals - those will pass dirt into the brgs, so they are usually shortlived. I upgrade to something with rubber seals. That seems to be the right mix of price and better design. They prehaps have a little more drag than metal, but they don't pass dirt, hold lube and seem to last. I run rcs that tend to weigh a bit so whatever addd drag from rubber seals is not significant. In lighter rcs where it might be a concern, teflon sealed brgd supposed to eliminate the drag.
To me what makes a good brg - one that actually can keep dirt and grit out, holds lub (doesn't leak it out everwhere and turn into a dirt magnet) and has a good service life. Low internal drag would also be a factor, important to some and not so important to others.
Duster_360 is offline   Reply With Quote
Old 11-17-2008, 06:55 PM   #3
Trader Rating: 54 (100%+)
Another factor would be the abec grade of the bearing and the simple fact that some of the cheaper bearings are made of lower grade metal which reduces longevity.
jsmax is offline   Reply With Quote
Old 11-17-2008, 07:24 PM   #4
AlanHall's Avatar
thats what im asking ... what materials and what seals are the ones to get ... is the rule different for engine bearings to clutch bearings??
Alan Hall
Old 11-17-2008, 08:54 PM   #5
Integra's Avatar
Unless your paying less then 1$ a peice for standard sizes...or getting ceramics for less then a buck or 2 i would just go with Avid or Protec or even Boca has a 1$ line up....for motor bearings you want ceramics....and quality ones at that...check Boca's site for more specs on the balls and sheilds used.
Old 11-17-2008, 08:57 PM   #6
AlanHall's Avatar
if they are selling them for that much.. im sure they will be cheaper..
Alan Hall
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Team Corally RDX Touring Car Kenshin Electric On-Road 10561 11-20-2015 11:54 PM
Avid bearings decent quality? Cannondale1974 Nitro Off-Road 84 06-06-2015 06:12 PM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Methods for cleaning/lubricating bearings? Chris__RC Nitro Off-Road 37 04-24-2009 07:35 PM
xray4life / Marcus Malone...just another Farmington, MI sneak-thief Scottrik Buyer/Seller dispute and Feedback discussion forum 62 07-29-2007 05:31 PM
