Old 11-17-2008, 11:52 AM   #1
Default buggy cleaning?
Hey guy's, had a bit of a mud race yesterday with the new buggy and it got covered! Ive begun cleaning today, cleaned the shell and wheels/tyres with hot soapy water, removed radio tray and engine. Brushed dry mud off engine as best i could then covered in gt85 (simular to wd-40), same goes for the radio tray. I washed the rest off with hot soapy water and dirt bike cleaner then rinsed. Covered that in gt-85 then used compressor across it.
Would you guy's consider this the best option or not? Should i proceed to strip the car down and check all bearings and parts etc or is it not neccessary everytime? -Hugh
hugh_b is offline   Reply With Quote
Old 11-17-2008, 12:34 PM   #2
slaytanic's Avatar
Trader Rating: 20 (95%+)
I would definitly check your hub bearings at a minimum. I found alot of moisture there that just never goes away. Also try lemon pledge instead of wd-40. It is incredible. Works better than wd40 IMO and instead of attracting dirt it repels it. Plus it doesn't make your buggy look like you dipped it in oil.
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 11-17-2008, 12:42 PM   #3
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i would disassemble and check things out.. mud racing is hard on bearing and bushings.. also check all of your hingepins and make sure they are moving freely
jamminnay is offline   Reply With Quote
Old 11-17-2008, 12:50 PM   #4
yep hugh,
i was there with you i believe you had the yellow d8, defo strip it down buddy, i done the 2 finals yesterday after poor qualifiers after the a main my car was solid.
i have jet washed and gt85'd it for now, but over the next few days the diffs will be coming out, the bearings in the front and rear hubs will be coming out also has mentioned check the pins and the arms they may need reaming to free them up.
its worth doing it buddy otherwise it will bite you in the butt later !!
Megacrash is offline   Reply With Quote
Old 11-17-2008, 01:08 PM   #5
ok cool, will do! yeah i had the d8! Is it worth stripping the diffs down and replacing the oils, can't remember if i have to anyway to get to some of the bearings
Old 11-17-2008, 01:11 PM   #6
Charles Godwin's Avatar
Just rebuild the whole car matey. Atleast you'll know everything has been checked and anything dodgy replaced
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 11-17-2008, 01:20 PM   #7
ok cool, just checked to remind myself and diffs will need to be stripped anyway so full overhaul it is, no doubt it's worth it as it will only cost a little in oils. With regards to shocks should they be re-built aswell or should they be ok?
Old 11-17-2008, 01:55 PM   #8
Rebuild, mud gets everywhere and has probably messed with the o-rings and if so has 'contaminated' the shock oil...
Old 11-17-2008, 02:58 PM   #9
j_blaze14's Avatar
Trader Rating: 34 (100%+)
after a mud race i let the car sit a bit then tap off the big chunks of mud with a screw driver handle on the bottom of the chassis. take off motor and radio tray then hose down the whole car. good foamy coat of simple green thenlet it sit a few minutes. hose it down again with good pressure in the noocks and crannies. air compressor it dry then squirt wd-40 or aro in the exposed bearings and ito the diff housing through the outdrives. wipe the car down with a damp wd-40 rag then compressor some more. should look new. the motor i remove filter and pipe and cap both off, spray with naphta then brush and compressor. wd-40 then compressor again. radio tray gets thin coat of simple green, brush, rag then compressor. theres a total of 12 exposed beaings (most buggies) and 6 hidden bearings so make sure they all get some sort of rust protection always, even after dry races cause some tracks use calcium and it attracts moisture.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 11-17-2008, 05:21 PM   #10
jpz_67's Avatar
Trader Rating: 56 (100%+)
This is almost my cleaning procedure to the tee and never any rusted bearings or metal parts. Been doing this for 7 years now with great results.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 11-19-2008, 11:08 AM   #11
El Tigre's Avatar
After a mud race I break the entire car down to the diffs and lather everything with simple green and then pressure wash with a puenmatic engine cleaner gun. The mud just falls out no matter how caked on. I then use a RPM bearing cleaner and spray WD-40 on the kingpin and diff bearings to get any remaining grit out. As a anal retentive measure against moisture build up, after cleaning I run the buggy for a few high speed laps on pavement to burn any remaining moisture in the bearings and it circulates the WD-40.
Every third race I break down the diffs and shocks and check the gears and replace the fluids.
El Tigre is offline   Reply With Quote
Old 11-19-2008, 12:16 PM   #12
Sam-E's Avatar
I dont race if its muddy, saves a lot of time and effort cleaning up!!!
TMORC - Official Club for the 1/10th Offroad Electric Worlds, 2012!!
Sam-E is offline   Reply With Quote
Old 11-19-2008, 12:29 PM   #13
We would never race in england if we lived by that rule!!
Old 11-19-2008, 12:31 PM   #14
Akhor's Avatar
I hear you on this!
Akhor is offline   Reply With Quote
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Adelaide Nitro Offroad Racing Club oblivion Australian Racing 19736 01-14-2017 01:12 AM
MADRRC (Maryborough & Districts Radio Rallycross Club Oztiger Australian Racing 2033 09-16-2013 02:42 AM
Ofna Hyper8 stingray schmelme Nitro Off-Road 804 07-13-2011 09:45 AM
cleaning the hard places CEN ENTHUISED Nitro Off-Road 53 09-23-2008 05:15 PM
Traxxas revo Jake Y. R/C Items: For Sale/Trade 17 05-11-2006 07:40 PM
