Old 11-16-2008, 11:16 PM   #16
sickboy's Avatar
Trader Rating: 72 (100%+)
I ran hitech 5955's with lipo and no regulator in my losi's for 18 months. they are now in my jammin and still kickin.. as for the servo screws, order 2.6x6 cap head screws and you worries are over.
Tamiya America www.tamiyausa.com
Team TRF www.teamtrf.com
Pro-Line www.prolineracing.com
818Designs.net - TKO
sickboy is offline   Reply With Quote
Old 11-17-2008, 12:18 AM   #17
Originally Posted by robbdny View Post
I was thinking of ace what servo horn are they compatible with? I like the case also
Ace/Xp servos use Futaba horns.
Losi-Runner is offline   Reply With Quote
Old 11-17-2008, 12:29 AM   #18
losi_racer's Avatar
Trader Rating: 25 (100%+)
jr ftw
i use the 8800S and the 9100S
losi_racer is offline   Reply With Quote
Old 11-17-2008, 07:28 AM   #19
robbdny's Avatar
Trader Rating: 19 (95%+)
Originally Posted by Oasis View Post
I run analog servos on my throttle and digital servos on the steering..For throttle use you can have problems with digital servos..Digital servos dont like to be stalled (like what happens when you hit the brakes) when you stall a digital servo it increases the power to the servo to over come this "stall"..I run a good analog servo (airtronics 94357 or a 94358) and I have never had any problems with them..
Oasis,
Thanks for the tid-bit that is something that I didn't know. Let me ask you this; I have heard know thing but Horror stories about there customer service.
robbdny is offline   Reply With Quote
Old 11-17-2008, 07:32 AM   #20
robbdny's Avatar
I run a Lipo with a regulator, what is the advantage of not using a regulator? does it shorten the run time? I just bought a new DX3R is there a chance it can damage the receiver?
Old 11-17-2008, 07:54 AM   #21
fiveoboy01's Avatar
Trader Rating: 17 (100%+)
More voltage equals more torque and speed, at the possible expense of damaging or shortening the life of the servo. Some recievers can't take that kind of voltage either.
Best to check with the manufacturer of each component to see what sort of voltage they can handle. The majority of it can do 6 volts, but an unregulated 2s lipo at full charge is around 8 volts which can damage things if unregulated.
Bill
JR Vibe 50, and that's it!
fiveoboy01 is offline   Reply With Quote
Old 11-17-2008, 09:08 AM   #22
cdbias's Avatar
I run Airtronics 94360's. They are the "high speed" servo's with the blue heat sinks. Although I did burn up a throttle servo in my 8ight 1.0 I sent it back and had it in two weeks and the charge was $35. I know Airtronics has taken up to 3 weeks on return though.
I know you are using the 8ight 1.0 Rob. I think you can use the radio tray from the 2.0 on the old car. The radio tray/throttle servo issue has been addressed on the 2.0. Just make sure if you get the radio tray that you also get the linkages for the center diff. They are longer due to the fact that the radio tray sits 7mm more to the right of the car.
Thank You,
Casey Bias
Tekno RC | Jconcepts| Trinity | Hobbywing | MKS Servos | Elevation Sports | Code 3 RC |
cdbias is offline   Reply With Quote
Old 11-17-2008, 04:31 PM   #23
JayL's Avatar
curious how a 'brake stall' is any different than holding full steering through a sweeper etc.......
JayL is offline   Reply With Quote
Old 11-17-2008, 04:49 PM   #24
fiveoboy01's Avatar
A stalled servo cannot further overcome the load that it is under.
Steering through a sweeper, the servo is holding a position which it is commanded to do... If it can no longer hold that position due to the force on the arm exceeding the servo's maximum output torque, then it's stalled.
If you're at full-lock steering the servo should not be stalled either. It's simply at its travel limit(endpoint), unless your mechanical setup is incorrect and causing binding.
Bill
Old 11-17-2008, 05:57 PM   #25
robbdny's Avatar
Default 2.0 radio tray used in a 1.0 8ight?
Casey,
Are you sure a radio tray out of a 2.0 will work? That would be trick
Old 11-17-2008, 06:15 PM   #26
superdave2's Avatar
a jr z9100s man i think thats the best servo out there besides the 9100t
Team Terribles~ARCS Hobbies~Have Fun Hobbies~Answer-RC~Torco Fuel~Fastlane Graphix~ Caster Racing Products~Maxamps~Clockwork Racing Engines~BCG Industries
losi 8t dps .28 jr z9100s jr z9000t
spektrum dx3
superdave2 is offline   Reply With Quote
Old 11-17-2008, 08:03 PM   #27
bgbelden's Avatar
5955tg== 1 year in my 8ight and 1 year in my matrix. Now i run lipo w/regulator and still going strong.
''Life's tough ........
it's even tougher if you're stupid..''
-- John Wayne
bgbelden is offline   Reply With Quote
Old 11-17-2008, 08:49 PM   #28
Integra's Avatar
Casey,
100% fits.
Old 11-17-2008, 08:55 PM   #29
Scottmisfits's Avatar
Buggy - Futaba BLS451's
Truggy - Futaba BLS351's
Those are steering and throttle.
I have a 4 year old Ace 1015 servo that went from 1/8 buggy steering to throttle and now it's my crawler steering servo. It's still cooking.
I have huge issues with Hitec's customer service, or lack there of. It's my issue and I won't elaborate on it.
I have always been taken care of by both JR and Futaba. Needed Hitec 3 times in one year, have needed JR once, haven't needed Futaba's customer service yet.
Scottmisfits is offline   Reply With Quote
Old 11-17-2008, 08:56 PM   #30
Integra's Avatar
Originally Posted by CarCrazy View Post
I heard from a few, that the "bad boy top of the line" JR servos are the way to go with the Losi 1.0. I fed my Losi 5 servos over 5 months, so I'm probably going to say don't use Hitec TG series servos for throttle. LOL!
I laugh now but back then OMG I was tilted...
Try the JR...
...and yes I had a team Losi driver set up my linkage, lasted one night.
the Ti gears failed?
Jammin CRT .5 = 1/12 Truggy Team Kamikaze Nitro Off-Road 2269 07-02-2017 04:32 PM
8T 2.0 polarismaster Nitro Off-Road 15880 02-02-2015 10:31 AM
Ko Propo VFS-1 ESC Hebiki Electric On-Road 2492 10-14-2012 07:51 PM
Losi Truggy rcfreak24 Nitro Off-Road 1884 12-27-2009 12:53 PM
engine break-in help r/t Rookie Zone 22 09-11-2007 07:02 PM
