Old 11-17-2008, 07:38 AM   #31
Darin Z's Avatar
I had the same problem with my Losi until I started running the mesh real loose. When you set the mesh and you think its normal go a little further. The amount of flex the car has allows the crank shaft and clutch bell to hammer away at the spur gear, so something has to give,"the bearings" When I started running a loose mesh my problems went away. I could go several races without changing bearings. I myself run the Avid Revolutions. If you have had several failures your crank end my be bent or the clutch bell my be oblong and thus no matter what you do you may continue to eat bearings.
Darin Z is offline   Reply With Quote
Old 11-17-2008, 10:46 AM   #32
Ya, a tight mesh is for electric... LOL!
These 1/8th scale cars don't need such a tight gear mesh, it might not sound as good being a bit loose but its better for bearings.
CarCrazy is offline   Reply With Quote
Old 11-17-2008, 12:45 PM   #33
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
+1
jamminnay is offline   Reply With Quote
Old 11-17-2008, 04:45 PM   #34
losi_racer's Avatar
Trader Rating: 25 (100%+)
well the tight gear mesh could very well be it. because its not tight that it binds or that it strips clutch bells because since i had it ive never had to replace it. ill try messin with the mesh and make it looser
losi_racer is offline   Reply With Quote
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
Erratic high idle.... dualrevos Monster Trucks 20 04-08-2009 03:51 PM
I dont get "shimming" please explain... assivaen Nitro Off-Road 29 01-21-2009 09:45 PM
New and Used Revo Stuff all $30 shipped jonski R/C Items: For Sale/Trade 6 08-09-2007 02:10 PM
I hate Centax clutches!!!! sstupid Nitro On-Road 98 06-18-2007 08:55 AM
