Old 11-16-2008, 01:56 PM   #16
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
the panther ones are not bad or the boca ones.... i cannot remember what sizes the 8 ones are but you can get 10 for the other cars for $10...
jamminnay is offline   Reply With Quote
Old 11-16-2008, 02:15 PM   #17
losi_racer's Avatar
Trader Rating: 25 (100%+)
the inside are 5x13x4mm
and the outside are 5x10x4mm
can you get me a link to these bearings your talkin about? perferbly boca but if im replacing them everyweek dollar ones are ok 2
losi_racer is offline   Reply With Quote
Old 11-16-2008, 02:23 PM   #18
Trader Rating: 8 (90%+)
i bought a set of ceramic from boca in feb ran them all year. clean and lubed them after every event. they were like 36$ for 4 bearings but well worth it. just make sure you keep the bearing clean and lube but not too much beacuse you dont want any lube on the shoes or clutchbell that will create a lot of slipping and this heat. check your clutch bell if it looks discolorred because of excessive heat then something might not be set right.
franklucas is offline   Reply With Quote
Old 11-16-2008, 02:27 PM   #19
losi_racer's Avatar
well i need a new clutch bell now because when i was messin around after the main my cluch messed up big time. my composite shoe material like all went to the rear of the shoe and pushed my cb foward because my front bearing had discenigrated and thus ruining the teeth on my cb and the cb started to go into the tank. So now i gotta get a whole new clutch AGAIN because of the bearings and also a new cb and a tank
EDIT: before this tho my cb was fine, no discoloration, no teeth messed up, no nothin other then the bearings we failing. i didnt lube the outside of the bearings or anythin.idk if i was supposed to but neither did my lhs
Old 11-16-2008, 03:33 PM   #20
jamminnay's Avatar
here ya go:
inside: http://www.amainhobbies.com/product_...oducts_id/9015
outside: http://www.amainhobbies.com/product_...oducts_id/5725
also check your collet.. they can where out... if it is slipping it would case excess heat and kill your bearings also.
Old 11-16-2008, 06:19 PM   #21
mikenix's Avatar
Trader Rating: 21 (100%+)
Pete just put together the losi bearing in pairs. I have them for 4 pairs for 10.50
http://answer-rcusa.com/zencart/inde...products_id=39
In 10pk they cost $1.33 each in singles $1.55 each.
Hope this helps.
www.answer-rcusa.com
Contact me for details.....
When you sling mud, you only loose ground. - Fat Albert
mikenix is offline   Reply With Quote
Old 11-16-2008, 06:34 PM   #22
jamminnay's Avatar
well that would work also.. it is cheaper that buying the losi ones for $6 a pair
Old 11-16-2008, 08:32 PM   #23
Default Clutch Bearings
I change my clutch bearings often also. At $1 a piece you cant afford not to. My routine is i will put a new set just before the A-main then ill run them same bearings the next week for practice and the quals then change them again before the A. Seems to work fairly well for me anyway.
FentonRacing11 is offline   Reply With Quote
Old 11-16-2008, 08:35 PM   #24
advantage racing bearings are the best bearings I have ran since I started racing. I change my clutch bearings out just because they might fail. I can run 4 race weekends before I change them.
PUDDIN is offline   Reply With Quote
Old 11-16-2008, 10:40 PM   #25
losi_racer's Avatar
Originally Posted by jamminnay View Post
here ya go:
thanks bud, i guess ill be changin the bearings once a week now, mult. sites are sayin 2 so ....... and btw i just did change my collet because it did go out after like 3 weeks of racin, i have a new one in now. im thinkin my 427 crank shaft might not be just 100% straight ????
Old 11-16-2008, 11:14 PM   #26
Avid makes good bearings, and they are also $1.00 a pop. Just order $20.00 worth and you'll never lose a tank or bell again. Change weekly, and changing before your main or last qualifier is a good idea.
5x13
http://www.avidrc.com/shop/?action=i...=1&prevstart=0
5x10
http://www.avidrc.com/shop/?action=item&id=1
CarCrazy is offline   Reply With Quote
Old 11-16-2008, 11:55 PM   #27
losi_racer's Avatar
thanks cc, ill look into it, since were talkin about bearings i need to go around my whole buggy soon and do all my bearings. should i just get standard losi bearings or what
Old 11-17-2008, 12:27 AM   #28
ConciliumDesign's Avatar
Default Get some ceramics
Get the TKO clutch bearings and conical washers. I've used the same set for 4 races and they're like new still.
RC8, RC8T, SC8, Go Power, DX3R, custom fabrication and design
ConciliumDesign is offline   Reply With Quote
Old 11-17-2008, 06:48 AM   #29
Chill_Will's Avatar
Trader Rating: 32 (100%+)
5x13
5x10
I had good luck with the Avid bearings. Wow $1 a bearing! I been getting the shaft with no Diff oil!
Chill_Will is offline   Reply With Quote
Old 11-17-2008, 07:13 AM   #30
brian kadow is offline   Reply With Quote
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
Erratic high idle.... dualrevos Monster Trucks 20 04-08-2009 03:51 PM
I dont get "shimming" please explain... assivaen Nitro Off-Road 29 01-21-2009 09:45 PM
New and Used Revo Stuff all $30 shipped jonski R/C Items: For Sale/Trade 6 08-09-2007 02:10 PM
I hate Centax clutches!!!! sstupid Nitro On-Road 98 06-18-2007 08:55 AM
