Old 11-14-2008, 09:33 AM   #1
Default Clutch bell and flywheel fitting advice please...
Hey guy's, i have fitted the clutch and flywheel to my new sirio engine and bolted it all to the buggy. When i fitted the flywheel i had to play with shims so it would clear the casing and the carb, i'm pretty confident that it fitted ok as the guy in the shop was the one who told me to purchase the kyosho spacer kit.
I have fitted the clutch bell and i found if i put two shims at the back closest to the flywheel then the bearing then clutch bell then next bearing and end screw with washer it cleared the flywheel nicely but had some back and forth slop. However i fitted an extra shim before the screw and washer at the front but this seems to allow the bell to spin but not as well as the above set-up although there is no slop. What am i aiming for when fitting the clutch bell?
Should i have no slop, free movement and a visible gap between bell and flywheel?
cheers-Hugh
hugh_b is offline   Reply With Quote
Old 11-14-2008, 09:41 AM   #2
Trader Rating: 42 (100%+)
I don't know all about the setups you are trying to use, but I will explain what I shoot for when setting mine up. I like for the clutchbell to spin freely. Meaning, no binding of any kind whatsoever. I don't mind a touch of end play as long as I can take a finger and spin the clutchbell without any drag. For me it is something I had to play with (trying different shim combinations) to get it where I wanted it and sometimes I will adjust it. The main thing I would shoot for is no binding of the bell. You also want to make sure the bell is not rubbing anything else as well.
Hope this helps
mracer is offline   Reply With Quote
Old 11-14-2008, 09:42 AM   #3
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
cheers-Hugh
You should have a TINY bit of slop, about 1 shim's thickness worth, free movement, and the clutch bell should not touch the flywheel, but also it should not leave ANY portion of the shoes visible- they should fully contact the bell as they extend with rotation.
Sounds like you have got it about right... probably just need to remove that end spacer, or possibly one of the ones behind the inner bearing. You should use enough spacers behind the flywheel to keep it from rubbing on the front of the motor, but only just enough for that... enough spacers between the nut holding the flywheel and the rear bearing of the clutch bell that the bell is not rubbing on the flywheel, shoes, or pins that hold the shoes, and enough spacers outside the final bearing (if any are needed) to allow it to spin freely with just a TINY, MINISCULE amount of play. If there is no play the bearings will fail very rapidly as everything heats up and expands.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 11-14-2008, 09:46 AM   #4
nice one guy's, very helpful, will go and adjust now...
Old 11-14-2008, 05:49 PM   #5
About .4 of a MM front to back play.
Look at the FAQ about what causes a clutch to eat bearings.
http://www.avidrc.com/shop/?action=support#life
TKO lists a the amount of play even with their CB shims.
http://tkocompetitiondev.com/shop/pr...roducts_id=261
butch man is offline   Reply With Quote
