Old 11-13-2008, 03:54 PM   #1
TRYMY4.0's Avatar
Trader Rating: 10 (86%+)
Send a message via AIM to TRYMY4.0
Default ◄◄Really Need Help with New T-Maxx►►
My co-worker just got a new T-Maxx 2.5 RTR. We called Traxxas and they were no help. Here are the problems:
1. It shutters in neutral
2. It starts creeping away w/ no brake
3. Transmission has a hard time from FWD to Reverse
4. The engine will smooth out. LIke almost no compression.
5. The idle will not come down
We've tried almost everything. Im thinking maybe the trans is the problem that could solve a few things. They said it shouldnt creep and should shutter a little bit. But it does it a lot. Even when shifting gears.
Any help would be greatly appreciated!!
-Ant.
TRYMY4.0 is offline   Reply With Quote
Old 11-13-2008, 04:35 PM   #2
Suspended
Trader Rating: 440 (99%+)
It really sounds like the whole problem is that the idle is too high.
There are 2 things that will cause a high idle 99% of the time.
One is the idle screw being too far out. You should take the air filter off the carb and look into the carb and the slide when at idle should have about a .5-1mm gap set for the idle.
If that is set correctly check your low end needle as that's the second thing to look at. Having a low end set too lean will also cause a high idle that lots of times won't ever allow the engine to idle correctly.
Check and set the idle screw FIRST.
Then double check your high and low end needle settings and reset them to break in specs according to the traxxas manual. After this make sure to NEVER adjust the idle screw again and retune the engine. Set your high end first and then set your low end. Traxxas has a very thorough and detailed write-up on their site about engine tuning that should help you.
Here is the tuning page on traxxas.com:
http://www.traxxas.com/support/kb_se...l&cat=0&id=276
Also here are the factory carb needle settings according to Traxxas.com:
http://www.traxxas.com/support/kb_se...l&cat=0&id=450
MattP is offline   Reply With Quote
Old 11-13-2008, 06:20 PM   #3
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
yeah i would start with the idle and see where that takes you
jamminnay is offline   Reply With Quote
Old 11-14-2008, 05:27 AM   #4
TRYMY4.0's Avatar
I appreciate all the help. So far I noticed the low speed screw was turned WAY out for some reason. So I set it to where it says in the URL u sent me. Hopefully this works.....
-Ant.
