Old 11-13-2008, 08:41 AM   #1
yai
Default Hw much slop CVDs get b4 replacing 'em?
Basically what is the general consensus that everyone has came upon?
At the death of engine's compression (8~10gals)?
1mm worth of play (back and forth)? Perhaps 2mm?
Thanks!!!!!!
yai is offline   Reply With Quote
Old 11-13-2008, 09:11 AM   #2
BAUSTIN's Avatar
i rebuild mine every couple(3-4) races........but i run them as long as possible once the drive pin wears about half way through the wear will slow......
Billy Austin
www.Code3RC.com
Elevation Sports
BAUSTIN is offline   Reply With Quote
Old 11-13-2008, 09:31 AM   #3
rced1's Avatar
Trader Rating: 17 (100%+)
I would replace my cvds, unis, or drive cups somewhere between 1 and 2mm. I also flip the drive cups when one side starts to wear too much.
An rc motor can last anywhere from 3 to 10 gallons depending on the qaulity and how it is treated.
rced1 is offline   Reply With Quote
Old 11-13-2008, 11:02 PM   #4
Trader Rating: 5 (86%+)
Thanks guys
Errr wouldn't the amount of play will remain the same? I'm not mockering, just tht I really need to know
FM 75.710
razor_clawzz is offline   Reply With Quote
Old 11-14-2008, 06:04 AM   #5
rced1's Avatar
The play would remain the same, but if you notice the drive cups only wear on the side driving your car/truck forward. By switching the drive cups, frontto rear or left to right, you have a nice straight edge on the forward drive side. This is only to get a little more life out of a drive cup. If you clean and rebuild your diffs regularly it only takes a few minutes to switch the cups.
