Old 11-10-2008, 07:48 PM   #1
Default Digital or Analog for throttle servo?
Just after some opinions on what you think is better for a throttle servo.
Digital's use more power but are more accurate. Is that accuracy needed on the throttle though?
Steering is another matter and digital is a definite but Im not so sure about throttle?
This is for a 1/8 buggy.
herb99 is offline   Reply With Quote
Old 11-10-2008, 07:54 PM   #2
Reevo's Avatar
Definitely go with digital. Doesn't hafta be top dollar like JR/Hitec...Go with Ace or something like that...They have nice digital servos for around $70 or so.
I got some RC stuff.
Reevo is offline   Reply With Quote
Old 11-11-2008, 07:03 AM   #3
allan42r's Avatar
look at speed, torque and will it return the carb to the closed postion if you loose power with a rubber band or return spring? the digital will have no problem but the analog you will have to check by removeing it from the package and see how free it moves. if you race dont use the fail safe mode. in nitro the pitman or a friend turns the car off we hope but if its left on and the radio gets turned off the digital servo will be buzzzzin away with full brake till it burns up. i lost a servo and learned the hard way. i run digital servos and will never go back to analog.
Pinky kisses better than mason's mom
allan42r is offline   Reply With Quote
Old 11-11-2008, 07:42 AM   #4
You are an anle log.
brian kadow is offline   Reply With Quote
Old 11-11-2008, 08:03 AM   #5
allan42r's Avatar
whats that they say about those who live in alabama?
Old 11-11-2008, 11:19 AM   #6
Chill_Will's Avatar
Trader Rating: 32 (100%+)
Uhhhh, they have the #1 football team that has not been beaten?
Chill_Will is offline   Reply With Quote
Old 11-11-2008, 11:57 AM   #7
allan42r's Avatar
not into watching men grab each other.
Old 11-11-2008, 12:04 PM   #8
Dont set your failsafe with brake on, just set it at idle and you will never burn a servo again.
FactoryTeam08 is offline   Reply With Quote
Old 11-11-2008, 12:14 PM   #9
moeman's Avatar
Trader Rating: 26 (100%+)
Yeah my buddy lost a new 9000S that way. It pulled brake for 2-3 hours before she gave up the fight
moeman is offline   Reply With Quote
Old 11-11-2008, 02:03 PM   #10
LOW ET's Avatar
Trader Rating: 95 (100%+)
do digital servos need to be programmed to use or can you plug it in and go? i thought i read somewhere you need a programmer to use one.
LOW ET is online now   Reply With Quote
Old 11-11-2008, 02:09 PM   #11
allan42r's Avatar
no they dont you can plug n play
Last edited by allan42r; 11-11-2008 at 02:19 PM. Reason: low et didnt understand me.lol
Old 11-11-2008, 02:12 PM   #12
LOW ET's Avatar
no plug n play
what do you mean?
no programmer needed, just plug and play?
no i can't plug and play?
Old 11-11-2008, 02:14 PM   #13
No digital dont need to be programmed.
I run an analog Hitec 965 throttle servo in my truggy and have had 1 year of trouble free use.
A digital servo will hold their position with the same strength throught out its entire travelling distance and will hold center more than an analog.
While this is helpfull on a steering servo I dont think that is needed on a throttle servo.
Might stick with Digital for steering and analog for throttle.
Old 11-11-2008, 03:04 PM   #14
Thistle's Avatar
Send a message via MSN to Thistle
I also use analog for the throttle/brake... I don't think the "holding power" is required for this application. I only run digital for steering.
Thistle is offline   Reply With Quote
Old 11-11-2008, 05:13 PM   #15
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i always run digital in both...
jamminnay is offline   Reply With Quote
RC FLIGHT brading Manila Racers 23110 12-24-2015 06:23 PM
Futaba FASST VS Spektrum DSM Artificial-I Nitro On-Road 110 05-09-2010 05:39 PM
Best servos for 8T 2.0 hairdog Nitro Off-Road 22 05-20-2009 09:41 PM
Digital Servos Hpimichael Nitro On-Road 45 01-06-2008 03:19 AM
Servo for Throttle? hot_version Nitro On-Road 11 07-05-2006 12:49 AM
Servos for new car Neil Rabara Nitro On-Road 17 02-01-2003 07:48 PM
