Old 11-10-2008, 07:31 PM   #1
CanyonCarverR1's Avatar
Default Drag Brake
Anybody use drag brake?
CanyonCarverR1 is offline   Reply With Quote
Old 11-11-2008, 12:33 PM   #2
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i use drag brake in my electric stuff...
jamminnay is offline   Reply With Quote
Old 11-11-2008, 01:42 PM   #3
What kind of vehicle?
In 2wd electric drag brake is common because they tend to spinout if you get too hard on the manual brakes and drag brake helps with turn in.
4wd with open diffs it is not common in that a 4wd is more consistent on manual brakes than a 2wd, and drag brake causes a 4wd to nose dive over jumps if you don't stay on the throttle just right.
GO-RIDE.com is offline   Reply With Quote
Old 11-11-2008, 03:31 PM   #4
BradBaker's Avatar
When i ran 2wheel electric buggy i used a lot of drag brake to help turns. I have no drag brake set up on my eight scale.
Sportwerks/turmoil
Futaba radios
Hitec servos
Pro-line tires
Hobbytown usa
"IF YOUR NOT FIRST YOUR LAST"
BradBaker is offline   Reply With Quote
Old 11-11-2008, 03:40 PM   #5
jamminnay's Avatar
+1 i run drag brake in my 2wd buggy.... i have never ran any in 1/8 scale..
Old 11-11-2008, 04:58 PM   #6
jrwoodchuck's Avatar
I used it in electric, but after I started racing eighth scale I don't use it at all in my brushless electrics any longer.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 11-11-2008, 05:20 PM   #7
BradBaker's Avatar
I think theres few to known that run drake brake no one around my area atleast.
Sportwerks/turmoil
Futaba radios
Hitec servos
Pro-line tires
Hobbytown usa
Old 11-11-2008, 05:56 PM   #8
Sorry, I thought that since this is the "Nitro Off-Road" forum it was clear that I wasn't talking about electric.
I was asking about Nitro, specifically 8th scale buggies.
Old 11-11-2008, 10:07 PM   #9
Trader Rating: 14 (100%+)
Dragging brakes is a decidedly bad thing.
I can see from a performance standpoint, where it may seem like you should be always on the throttle or the brake, however in practice this theory does not work.
It wont take long before the pads and discs heat up, hot enough to begin melting plastic parts and eventually bind..
Infact it took R. Cav about 11 minutes during the worlds main for this exact situation to pan out. Its a whole different sort of idea on a free spinning electric motor. While some could argue that the performance gains would be beneficial (though being smooth will do a lot more for your lap times than throttle-brake-throttle-brake) nitro cars are simply not set up for this.
I do wonder how this will pan out in 1:8th brushless, where the resistance is again on an electric motor.. time will tell.
Seyruuen is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
E Crawler catkchun Malaysian R/C Racers 1152 05-02-2011 08:58 PM
Brushless Modified Cogging/Drag Brake Effect per different brands... StickyFingaz Electric On-Road 8 04-10-2008 07:07 PM
Top Driving Styles: Using Brakes and Drag Brakes SlamMan Electric On-Road 32 04-30-2007 10:11 PM
Tekin stulec52 Electric On-Road 443 01-17-2006 06:06 AM
