Old 11-08-2008, 05:11 PM   #1
Default setting ride height?
Hey guy's, i'm wanting to set my ride height on my new d8 to the standard set up of 29mm. I went into my lhs to buy a ride height gauge but i was told they don't stock them and never really have as you can just use some digital calipers. I have set the shock lengths/droop with the digital calipers measuring from the middle of the top shock bolt to the middle of the lower bolt as accurately as possible with the car off the ground if this is correct (adjusted using the droop screws)? However i'm unsure how to measure ride height with calipers as i thought it was adjusted via the shock collars with the car on the ground? Can any one help? thanks-Hugh
hugh_b is offline   Reply With Quote
Old 11-08-2008, 05:28 PM   #2
Integra's Avatar
u are correct on the ride height being adjusted with the spring collars....you need an Ae ride height guage....using caliper's imo is more of a hassle.
http://www.amainhobbies.com/product_...ducts_id/13177
Old 11-08-2008, 05:31 PM   #3
just what i thought! They were telling me just to measure from shock end to shock end!
Old 11-08-2008, 08:42 PM   #4
Integra's Avatar
show's how much they know about set-up
Old 11-09-2008, 12:27 AM   #5
Chill_Will's Avatar
Trader Rating: 32 (100%+)
If you are not in a hurry you can wait and save some money.
http://www.horizonhobby.com/Products...odID=LOSA99173
Chill_Will is offline   Reply With Quote
Old 11-09-2008, 02:26 AM   #6
Mark_Australia's Avatar
Ride height gauge is a ripoff IMHO.
Put car on a box about 12" high, and the box on a table.
Place a ruler (or bit of steel or anything) under the car so it lays flat under the chassis. Hold it up against the chassis but being careful not to lift the car. Tape it on there if you want.
The ruler will stick out 4" each side (or front - back if using a long one)
Measure from top edge of ruler to the top of the box.
Done.
Mark_Australia is offline   Reply With Quote
Old 11-09-2008, 07:25 AM   #7
Integra's Avatar
Done.
haha thats hilarious....for a whopping 15-20$ you seem to think a cardboard box and ruler are just the same.......too funny.
Old 11-09-2008, 07:25 AM   #8
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
a ride height gauge is much easier to use at the track for adjustments then carrying around a 12 inch high box..IMO
Done.
jamminnay is offline   Reply With Quote
Old 11-09-2008, 07:30 AM   #9
Integra's Avatar
is this guy really serious....a Box and ruler
Old 11-09-2008, 07:54 AM   #10
Trader Rating: 19 (100%+)
Default Setup
Using digital calipers is really easy to. Just leave the car on the setup station and measure from the setup board to the bottom of the chassis. That simple.
Jmnay_83 is offline   Reply With Quote
Old 11-09-2008, 12:51 PM   #11
Integra's Avatar
what about when you want to measure the front height behind the kick up....caliper blades are only soo long. or if u sport a rear skid plates and u cant just measure from the rear of the chassy and you have to go in front of the plate or on one of the droop tabs where the skid does not cover....good luck getting caliper's in there.
Serpent 705 J_Longbrake Nitro On-Road 4252 02-22-2015 11:34 PM
Losi XXX-S TSR6 Electric On-Road 14329 01-26-2015 07:59 PM
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 03:19 PM
WHAT ORDER DO YOU SET YOUR CAR UP? crACkeD ChaSsiS Electric On-Road 23 03-29-2006 03:18 PM
Tweaking a touring car? 429racer Electric On-Road 111 09-26-2004 06:24 PM
